Waste of time head swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2020, 09:14 AM
I need y’alls honest opinion. At this point I just can’t leave my truck alone!
I have a “built” standard bore 350 with flat top pistons, a 540ish lift 260ish duration cam, screw in rocker arm studs and some rollers on solid lifters/stud girdles. Running an Edelbrock intake and a q-jet carb. Standard .041 head gasket.
“Problems” is that these are some 305 H.O. 601 heads. The gentleman who built the engine says they have the 1.94 intake 1.6 exhaust valves and have been machine to a 62-63cc chamber. He claims they are flowing as good or better than a set of vortec heads. Says he’s be super surprised if slapping on the vortec 64cc heads would yield any better power. Obviously the valvetrain has been upgraded for the high lift cam.
After getting of a disagreement with the builder, some of you may remember previous posts of mine, he has given me that addditional info. He says SCR should be right around 10:1.
I know running pump 93 with 36 degrees total timing there is no detonation, so I’d assume the heads were machined. Stock these heads are 53cc chambers and with flat tops I would think it would hardly run on pump let alone keep its self from detonating to death. I just don’t feel like I’m getting the power I should. It’ll roast the tires and chirp third gear but I feel like it’s got a 0-60 time of more than 6 seconds. Running this in a single cab 5 speed nv3500 c1500 with 3.08 gears so maybe it’s in the gearing. I manage a repair shop so I get the chance to drive quite a few cars. I’d assume with the flat tops and the cam I’d be putting 400 to the wheels with the right heads? Or am I over estimating that? My butt Dyno says I’m pushing no more than 300-325 or so.
Opinions? Waste of time swapping the heads? Minimal gains? Try gearing first (which will be don either way)?
Old 01-12-2020, 10:38 AM
johnsongrass1's Avatar
Race it, Don't rice it!
The fact that the previous owner thinks the 305 head is a good head has me walking away from the conversation.
A stock Vortec head is better performing everywhere regardless of the how well the 305 heads are worked over.
The Following User Says Thank You to johnsongrass1 For This Useful Post:
PHWOARchild (01-24-2020)
Old 01-12-2020, 10:49 AM
ericnova72's Avatar
More for Less Racer
Originally Posted by johnsongrass1 View Post
The fact that the previous owner thinks the head is a good head has me waling away from the conversation.
A stock Vortec head is better performing everywhere regardless of the how well they are worked over.
I agree, even a full time head porting pro will have a tough time getting the 305 head to flow as good as a stock Vortec head.....a small time machine shop/engine rebuilder has about a snowballs chance at the equator in July of achieving that.
400 HP at the wheels means you need to make 500 Hp flywheel....you are not making that right now....but Vortecs won't get you that either.
Old 01-12-2020, 11:12 AM
I have a 1968 Chevrolet 350 CI engine in my 1962 Chevrolet with 1962 double hump heads that have 64 cc combustion chambers and .041” deck clearance. . The compression ratio is calculated at 10.3:1 with the following fuel mixture.
I got detonation under load with pure Mobil/Exxon 92 octane premium unleaded, winter blend and summer blend. I pour in five gallons of VP C12, 112 (R+M/2) leaded pump octane race gas with fifteen gallons of 92 octane premium pump gas and there is no detonation even on a hot day with 210 degree engine temperature. That mixture creates about 97 octane in the tank.
(% A) x (octane A) + (% B) x (octane B) = octane of mix
(.25 x 112) + (.75 x 92) = 97 octane.
A = race gas
B = pump gas
The five gallon sealed container of VP (green) C12 race gas costs $70. The local race shop keeps that fuel in stock. It is the most popular VP leaded fuel to mix with pump gas that will work for street performance engines with up to 12:1 compression ratio. If you have more than 11:1 compression ratio, you should use 100 % VP C12 rather that mixing it with any pump puke.
Old 01-12-2020, 11:50 AM
Well, I should trust my gut in these scenarios but I always trust y’all a opinions. I’ve read, heard and seen how well the Vortec/aftermarket heads flow and I knew these 305’s were chocking down the engine. Vortecs/aftermarket it is. I’m super tempted to Dyno it before and after.
Old 01-12-2020, 12:08 PM
look at Profiler heads before you randomly buy some "aftermarket" Vortecs. 0-60 in 6 seconds is pretty good. Whats your 0-100?
I doubt your 305 head engine is making 400 hp?
Old 01-12-2020, 12:39 PM
You'll see coolant long before you can make a 305 head flow enough for 400 horsepower. About 350 is all they have in them and that takes a lot of tricks in other places. This is a head where high lifts are mostly a waste of time. Here you need to deal with the inability to make these smallish ports flow to the amounts that 400 horses need to feed on. The answer here is more duration with not so much lift. The excess lift cannot be used by the port as it cant flow enough to feed the bigger curtain area at the valve; the same holds to some extent of valve size. So all the big lift numbers do is incease wear and tear on the valve train be requiring high spring pressures for no power benefit.
305 heads then need a lot of duration so the small ports have additinal flow time to compensate for their lack of peak flow capability. This results in a long duration cam that must close the intake valve late in the cycle, to compensate for this the compression ratio needs to go up high to gain back the compression pressure lost to reversion created by the rising piston against the still open intake valve late in the compression cycle. To overcome the reversion takes enough RPM to increase the port flow velocity to where it develops enough inertia to overcome the reverse pumping of the earlier inducted mixture taken in on the pistons downstroke. While small ports will cause this inertia to build early, the port still has its physical limits and you can't keep the intake off its seat forever to compensate for the ratty flow numbers and other operating issues that flow bench values have no way of considering as it relates to pressure building behind the closing valve as relates to pocket volume and reflected pressure waves in the port, and of course the maximun Mach number the port can sustain before it generates standing sonic shock waves that block flow. This actually happens at fairly low average port velocities. An average port is done well before .5 Mach; for a 305 probably less than .4M. So there are a lot of sticky issues hiding in here.
The other is the 3.08 probably with a large diameter tire just doesn't turn the motor fast enough to let it run in it's better power range. Then there are all the issues of getting crankshaft power to the pavement. This being the mostly an unsung zone of chassis, driveline, and suspension rocket science that has to be done along with the engine power. This is difficult, expensive, and not appreciated but if you want to go fast, you gotta put a lot of homework here. It's not as flashy as big power numbers on a dyno but if you know how to do it, you can put a lot of people with way bigger power numbers on the trailer.
Last thing is you enter into a zone where it takes increasingly large power increases to net small gains, it just gets harder to get big effects as the speeds go up. Power grows in a somewhat linear fashion as resistances and consumptions increase in exponential fashion, the physics fight you every step of the way.
Bogie
Old 01-12-2020, 03:16 PM
Originally Posted by MouseFink View Post
I have a 1968 Chevrolet 350 CI engine in my 1962 Chevrolet with 1962 double hump heads that have 64 cc combustion chambers and .041Ē deck clearance. . The compression ratio is calculated at 10.3:1 with the following fuel mixture.
A = race gas
B = pump gas
Crazy thing is, I can get 36 degrees out of this motor on 93 with no detonation at all. Which actually leaves me with more questions than answers!
I guess this pretty much sums up what I already figured. Now the big question would be how much gains could be made swapping over and if those gains are worth the effort? Only one real way to know I guess. It would surely suck to take the time, effort and money to see minimal performance increases.
Old 01-12-2020, 03:48 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Would you please explain the cam and rockers in detail. You have me confused. Roller, flat, rocker brand and ratio? Is this a solid roller with 260 at 0.050"? If so, it's not wonder you can't rattle the motor.
Old 01-12-2020, 04:16 PM
Sorry, flat tappet cam. No cam card but measured at about 540 lift and 260 duration. Solid lifters. Not sure of brand on rockers but they are 1.5 roller rockers.
Old 01-12-2020, 08:00 PM
This is 260 degrees at .050 or from zero?
Keep in mind that not all detonation is audible.
Bogie
Old 01-12-2020, 08:06 PM
predator carb guru's Avatar
Mark Goulette
Bogie
And the damage being done goes right along with this....that's how holes in pistons and broken parts are made....you never know until you know. And by then it's too late
Old 01-12-2020, 08:16 PM
Bogie
260 from .050
I understand. Unfortunately these donít have knock sensors but now Iím curious how to detect detonation that isnít audible?
Old 01-12-2020, 09:42 PM
put your car on a chassis dyno.
Back off the timing and make a pull
advance 2 or 3 degrees before each pull.
When power dips you can bet you are at or near detonation.
back timing to peak power, maybe minus 1 degree ?
now proceed with carb tune
recheck timing
do a valve lash tune if you want for another pony or 2
Lash loop also tells you if the cam is too big or you can use more
Old 01-13-2020, 11:39 AM
260 from .050
I understand. Unfortunately these don’t have knock sensors but now I’m curious how to detect detonation that isn’t audible?
Determining the minimum fuel octane requirement mostly comes from experience and help from others who have used Racing fuels. Knowing your compression ratio is a good place to start along with the engine timing advance.
I learned the racing fuel/pump gas mixture starting with pure 100% VP C12 race gas and slowly reducing the percentage until I detect audible detonation, then increasing the amount of race gas until detonation goes away. That is risky if you have hypereutectic cast pistons. That is called a “butt dyno”.
I have used forged pistons on every engine I have put together. Forged pistons gives your engine a extra margin of safety in case the ratio of the fuel mixture is not right.
