Water bumps in clear coat - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
  #16 (permalink)
Old 07-18-2016, 06:31 PM
1000 grit can be quite difficult to remove with a foam pad. And I'd wager that if you bend down and look up at the side panels, you'll see some sanding scratches still there as well.
I'd give it another go with the 2000-3000 trizac, to remove the remaining 1000 grit scratches.
Then polish it up.
But it's lookin' good so far.
  #17 (permalink)
Old 07-18-2016, 07:18 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Yep, just backtrack until you are rid of the crosshatching but keep the rule #1 in mind= use the least agressive method that works. 1000 grit is coarser than I like to go, for this reason. As time goes by, you'll likely notice more of those faint marks re-appearing, but you'll know how to handle it. The bird looks good glossy, don't it?
design ,stripes, wich paint base coat over spi clear coat Vincentnova Body - Exterior 1 08-12-2012 09:19 PM
Afraid to color sand my new base coat / clear coat. Can I go straight to fine cut? Zeeb Body - Exterior 12 06-12-2012 10:36 PM
spraying clear coat on top of clear coat? bennecc Body - Exterior 9 05-08-2012 05:59 AM
Clear Base coat vs Clear Top coat waterdude Body - Exterior 7 12-13-2010 12:11 PM
Clear coat bumps solvent pop? magnoman Body - Exterior 9 05-14-2007 10:58 PM
