Wax & Grease Remover on Freshly Blasted Steel - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2018, 07:22 AM
bing98's Avatar
I have to clean some hard to reach and complex areas of my undercarriage after blasting. Using towels of any sort would leave a shredded mess between the sand blast profile and all of the edges and holes in the floor pan and rails so I surmised that applying wax and grease remover with the red scotchbrite pad would provide the scrubbing/cleaning action to loosen the bad stuff. I would then give the area another quick spray of wax and grease remover to "float" the bad stuff and then blot vs wipe it off with a paper towel. I would follow with some compressed air to dry out the seams and overlapping panels.
Instead of a scotchbrite pad how about a plastic bristle brush to agitate the wax and grease remover?
Old 09-07-2018, 06:41 PM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
Simple Green to clean and then Wax and grease remover prior to paint. Use stiff bristle tooth brushes to get into the tight corners.
Mark
Old 09-11-2018, 02:35 PM
PHWOARchild's Avatar
Prep-Sol was always good when I used it.
what else in in wax and grease remover besides mineral spirits? Dubz Body - Exterior 47 06-19-2010 12:09 PM
Before base coat, use of wax & Grease remover rodder1 Body - Exterior 9 03-15-2009 09:11 AM
Glass cleaner after wax and grease remover? wreckedGTI Body - Exterior 20 06-17-2007 05:21 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
Wax&Grease Remover on Fiberglass T7SuperBee Body - Exterior 13 03-27-2005 06:03 PM
