Weeping bleeders - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2018, 06:55 PM
Weeping bleeders
Just replaced the rotors, pads and reman calipers on my expedition.
Got everything buttoned up and brake fluid is weeping from the bleeder threads. I've sprayed it down, wiped it clean and verified that it is dry, then rechecked after a drive and even just sitting all day (have rechecked several times) and there is always fluid around the threads.
As stated, they are reman calipers. I've verified they are tight. Loosened and tightened several times, and even gave them the full onion to get them to stop weeping.
Any thoughts? Am I just hosed and looking at another set of calipers? Odd that both sides are weeping the same....
Old 07-03-2018, 10:00 PM
Are they the correct bleeders for the calipers?
BB
Old 07-03-2018, 10:14 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
There is a similar problem on the Ford Truck forum. It took replacing the caliper with another one to fix the problem. It was thought that perhaps a worker at the rebuild facility was drilling out a stuck bleeder and that the angle of the drill bit did not coincide with the seat angle of the new bleeder screw.
Old 07-03-2018, 10:49 PM
BB <img src="https://www.hotrodders.com/forum/../images/smilies/thumbup.gif" border="0" alt="" title="thumb up" class="inlineimg" /><img src="https://www.hotrodders.com/forum/../images/smilies/thumbup.gif" border="0" alt="" title="thumb up" class="inlineimg" />
They are the bleeder screws that came with the reman calipers. They are brand new, but not sure how I would know if they are right.
I suppose I could try the old ones and see if they work, or buy new bleeder screws and see if they work.
That's my fear ... that I get to do it all over again....
I could see one of them being wrong or miss drilled, but to have both seems odd....
They don't feel right, though. As soon as you crack the screw, it wabels loosly in the threads..... Maybe just they mounted the wrong bleeder in the calipers? That would be better than having to warranty them out....
Old 07-04-2018, 05:47 AM
Bob37pont's Avatar
Curmudgeon at Large
Definitely the wrong bleeders, there should not be that much play in the threads. If the threads on those screws are not correct for the calipers, the seat angle may be wrong also.
I would try the old ones first
Old 07-04-2018, 06:52 AM
S10xGN's Avatar
Gotta love a turbo!
3/8 thread bleeders will fit where 10mm should go and be slightly loose...
Russ
The Following User Says Thank You to S10xGN For This Useful Post:
Bob37pont (07-04-2018)
Old 07-04-2018, 07:42 AM
That would make sense... I had to use my 3/8 inch wrench for the bleeder and no metric wrench fit which I found very odd.
I'll compare to the old ones and see what I can find. Might try the old ones and see if those work. I'd rather have new ones though since the old ones are pretty crusty.
I'll bet that's what happened. SAE bleeder in my metric caliper.... makes more sense than both of them being cracked or misdrilled.
Old 07-27-2018, 06:46 AM
Detana's Avatar
front and rear STOCK caliper bleeder screw size is M8X1.25 it is a standard size in the motorcycle braking component arena. the correct speedbleeder part # is SB8125. i believe they throw L's at the end of the part # to indicate increased length. they do work nicely and extremely handy for automotive purposes but IMO always found them to be a waste of money for street bikes. and your "weeping" fluid? can be caused by galled bleeder seat in caliper which is extremely unlikely(have never seen it on a street bike)....nicked/dirty/corroded bleeder seat also pretty unlikely on a 9 year old street bike....residual fluid on threads and bleeder that needs re-tightened. my solution when i run into this: have rubber plug handy....remove bleeder....do NOT touch lever or pedal....squeaky clean bleeder seat and threads....Qtip clean caliper seat as best you can....put a dab of thread sealant on the bleeder(i don't use tape)....and reinstall and tighten. always works.
"Weeping" SBC water pump XNTRCI-T Engine 2 06-21-2010 04:03 PM
Aluminum head weeping internally? HotRod60 Engine 12 08-18-2009 12:26 AM
Weeping Head Gaskets jleeheat Engine 15 10-20-2007 01:04 PM
weeping head gasket 67bucket Engine 2 10-22-2003 09:14 AM
9in Ford Axle weeping fluid 4DR Briggs1929 General Rodding Tech 3 05-13-2003 04:46 PM
