weird crack in block, is it somehow NOT a problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2018, 11:12 PM
bullheimer's Avatar
NEVER use credit cards!
i guess it's always a problem but still. i dont remember seeing this there last time i did anything but maybe it was there and maybe it wasn't. here is a pic of it. it's in a non critical area and i only see the crack at the top and not on either the inside or the outside. sbc. just a crack at the top of the sealing surface to the intake at the front of the block as shown. the crack is just below the hole. just want to say i doubt anybody is going to say anything that will make me junk my block. be more careful with it, yes; completely ignore it? Definitely!
Name:	crack in top of block.jpg
Old 05-28-2018, 12:40 AM
ericnova72's Avatar
More for Less Racer
That doesn't look like a crack to me, at least not from that picture. It looks more like a scrape or drag mark that occurred during handling. Cracks in cast iron generally have a grainy look to them.
You ae right, if it is a crack that is an odd place for one, as there is no stress of farce in that area. It wouldn't be any problem at all unless it goes all the way down to the camshaft bore.
The Following User Says Thank You to ericnova72 For This Useful Post:
joe_padavano (05-28-2018)
Old 05-28-2018, 12:57 AM
4 Jaw Chuck's Avatar
Looks like a mark from dragging the block across a bench top, doesn't look like a crack to me either. If it was you would see propagate on the inside or inside of the China wall.
— Han Solo
Old 05-28-2018, 07:37 AM
Forty2door's Avatar
Crack
I agree. However, if you have the engine out, I'd recommend taking it to a machine shop if you have one close by and have then Magnaflux it. Only takes a few minutes. If not, I would clean it really good and rub a little emery cloth over it and down each side and have a look with a good light. I worked for Magnaflux for over 31 years so I'm always suspicious of crack-like indications.
The Following 2 Users Say Thank You to Forty2door For This Useful Post:
64nailhead (05-28-2018), AutoGear (05-29-2018)
Old 05-29-2018, 09:35 AM
rub it lightly with some emory cloth, clean with alcohol and using a bright light held off-center, look for propagation (little spider lines). Thats very sharp looking, like a scribe mark, and its almost perfectly straight. One would thing it'd be closer to the hole, or have a curve to it, not be completely perpendicular and straight.
Back in the dark ages, guys used to use kerosene and fine chalk-dust, to do crack inspections...I mean check things for cracks.
Old 05-30-2018, 09:57 AM
bullheimer's Avatar
thanks guys, engine still in. will do the crack inspection when my wife gets home.
The Following User Says Thank You to bullheimer For This Useful Post:
AutoGear (05-30-2018)
crack in engine block for starter bolt. Jimbo17 Engine 9 02-28-2015 08:45 PM
Welding block crack? Viban Engine 5 03-26-2013 07:03 AM
Crack detection in SBC block v8hed Engine 1 11-05-2009 06:13 PM
355 block... small crack abas_abas Engine 2 03-06-2009 05:51 PM
Small crack in VW block Demondrive Engine 5 02-24-2004 08:08 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
