Weld-able coating for floorboards - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2006, 11:24 AM
cruzinTLT's Avatar
Lovin' The Cruzin'
I got my front floorboard steel patch panels for my '64 Corvair last week My question is: What can I coat them with so I can still weld them in while protecting hidden areas from future surface rust? I know there is weldable primer, but is that available in spray cans since I don't have a spray gun and compressor?
Thanks
Old 07-10-2006, 12:26 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I'm certain someone here will correct me, but I just finished getting the Floorboards (new Firewall back to Trunk) in my '35 done this weekend. I used SEM Weld-thru Primer for where I was welding (man, it splatters like heck). Anyway, if I were you (and of course I'm not), I would take them to someone who can Epoxy Prime them, have them painted, of course, tape off the areas to be welded before Epoxy, then spray Weld through Primer on the remaining areas and go to town-good luck, grinding all those rosette welds isn't fun (use Flap Discs!)-
FYI, I have heard good things about the 3M Weld Through Primer-
Old 07-10-2006, 12:38 PM
Back when I used lacquer primer I just primered between the seams with that but I doubt that it did much good. The 3M weld through, which is sold in spray cans, works really well just don't spray it on too heavy and it will weld just fine. I also have had good luck with the Dominion Sure Seal brand. I have found that just spraying this on an open surface will not completely prevent rust but when heated, such as would occur between seams while welding, it works quite well at preventing rust.
Old 07-10-2006, 12:54 PM
cruzinTLT's Avatar
Lovin' The Cruzin'
Thanks guys! I'll try the 3M stuff. I'm just concerned about areas that will be uncoated such as bare metal against floor braces and areas that will butt right up against other areas that will be impossible to coat once the welding is finished. I know I can seam seal some of the areas, but I just don't want rust to form after all that hard work is completed.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Welding info Kevin45 Body - Exterior 9 08-26-2011 08:09 AM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Question on Mig Welding - HOW to modas Body - Exterior 43 12-31-2005 09:48 PM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
