welding 2 cars together - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2003, 08:49 AM
dovaka's Avatar
New Member
ive been in the process of reuilding a 79 rs camaro but when i first bought the car the rear driver quarter had been into a accident and just the other day i got around to cutting that section out only to find that most of the back is totally rotted out alot more then i was expecting and would require me to replace almost everyting in the last 18" of the car but i was at my local junkyard the other day looking for parts and i ran into a 76 Z-28 shell no frame doors interior just the back half of the body and i know the guy that runs the junk yard so he will sell it to me for $100 now my car is totally stripped and i plan on completly removing the roof off so if i cut both cars in half would i be able to use the back half of the Z-28 and weld it onto the front half of my rs my only concern is that the doors wouldnt fit or that one might be a little wider then the other or some little thing like that right were they would get welded together
also i plan on cutting them right infront of the back of the door there is a seam there anyway so ill have something to keep the cut straight
thanks
Old 06-25-2003, 09:48 AM
Will's41's Avatar
I have done a number of clips over the years. I belive the 76 and 79 use the same body. You should make sure, look in an interchange book. I always used a spot in the center of the door and the center of the windshield. Use a common point to measure from and cut both cars the same. I always leave the doors on to check the fit before final welding. I also leave the wheels on both cars, it makes it easy to move them once cut. Clamp the cars together and use a few spot welds to hold it and check all of the alignment points. Very important: Make sure your cuts are square and straight. Don't use a saws all, the blade flexes giving a bad cut. Use a large carbide wheel or a cirular saw with a metal cutting blade will work too. Good luck, it's easier than it looks if you take your time on the measurements and cuts.
Old 06-25-2003, 07:50 PM
[email protected]
As I recall, that is a uni-body vehicle, with no real full frame to support it. Keep in mind that what you are planning on doing is dangerous, even for a qualified and experienced technician. I have seen that done numerous times, with disasterous results. They have been done in shops with very good reputations. All welds have to be perfect. Any failed weld or improper joint will increase the likelyhood of failure. The vehicle can break and cause serious injuries or even death, for any reason.
You also might want to check on the insurability of a vehicle with that kind of repair.
THIS HAS GOT TO BE ONE OF, IF NOT THE MOST DANGEROUS TYPE OF REPAIR THAT CAN BE ATTEMPTED.
Old 06-25-2003, 08:28 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
There`s nothing complacated about what you want to do. if you have never done anything like this before you should go snopping at some body shops that do that.
I try to do all the lap welds that I can,for added strength.
double check all measurments,likes been said leave the doors on,this will help alighn every thing.
You said something about removing the top,are you going to leave the top off? If so you`ll have to incorparate some bracing in the floor area.
If you are going to put the top back on ,don`t take it off,leave it attached at the windshield,this will make the job a lot easyer.
Hope this helps good luck;
Troy;
Old 06-25-2003, 09:38 PM
dovaka's Avatar
New Member
ok to answer some questions in no real order
yes i plan on leaving the roof off
i forgot to mention that im going to have the subframe welded together to sufficently take the force from the roof being removed
im going to cut the car and tack weld it together and my friend who is a pro welder is going to make all the real welds on the car as i dont trust my welding ability that much
any more questions and ill be back to answer them ive been spending most of the night out side measuring the cars and finding the best spot to cut them as to not go threw anything major on it
Old 06-26-2003, 04:09 PM
HI DOVAKA, I HOPE YOUR WELDING MATE IS **** HOT AT HIS JOB,BECAUSE IF NOT YOUR GONNA GET YOURSELF INTO A LOT OF BOTHER!
IN THE U.K. WHAT YOUR ATTEMPTING IS TOTALLY ILLEGAL.
IT"S CALLED "CUT-N-SHUNT",YOU TAKE A GOOD FRONT END OF A REAR END SMASH VEHICLE + WELD IT TO A GOOD REAR END OF A FRONT END SMASH VEHICLE! IN THE U.K. THERES BEEN A LOT OF DEATHS CAUSED BY THE VEHICLES JUST SNAPPING IN TWO ON THE SLIGHTEST IMPACT.
IT"S GONE THAT WAY NOW THEY"VE BEEN OUTLAWED,THERE"S NO WAY YOU COULD EVER GET THE VEHICLE INSURED
SURELY OVER THERE IN THE STATES YOU CAN PICK UP A DOZEN DECENT BODYSHELLS,WITHOUT RESORTING TO CANNIBALISM (CARNIBLISM THAT IS)
THERE"S BEEN CASES OVER HERE OF VEHICLES DRIVING AROUND WITH IDENTICAL REGISTRATIONS,WHEN THE VEHICLES ARE CHECKED OVER BY THE"STOLEN CAR SQUADS" THERE FOUND TO BE "CUT-N-SHUNTS AND TAKEN OFF THERE OWNERS(WHO MANY HAVE BOUGHT THEM UNKNOWINGLY AND DESTROYED! + THE OWNER COMES AWAY WITH NO CAR + NO REFUNDS!
DON"T DO IT MAN, COULD BE YOUR SONS SON WHO TURNS UP AT YOUR HOUSE ONE DAY AND SAYS" HEY GRANDAD COMIN FOR A RIDE IN MY MOTOR"?.. ..................PHILPKP
Old 06-26-2003, 08:27 PM
[email protected]
I cannot understand why anyone would want to try something like that. To do a "clip" like that is bad enough, but to remove the top also is definitely looking for major trouble. I sure hope that you keep that death trap up in the north east. I'm sure with the roads up there the way they are, and the rust problems from the winters, it will really be a treat.
Old 06-28-2003, 10:41 PM
dovaka's Avatar
New Member
i also said that i plan on renforcing the frame to compensate the removal of the roof
Old 06-29-2003, 01:29 AM
dinger's Avatar
why not bolt your front subframe to the z body? If these are the same generation, everything should bolt up between the 2 cars.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 06-29-2003, 09:58 PM
dovaka's Avatar
New Member
the car has to get cut regardless because im making it shorter so even if i just swaped the subframe over i would still need to weld it
Old 07-03-2003, 05:28 PM
I only know of one person that made a convertible out of a 3rd gen f-car and he was adament he'd never do it again. The car is so heavy so ALOT of bracing is required, which of course makes it even heavier. Of course, it still wasn't enough. Think about the cowl shake you've got WITH the roof on.
Another option, a bit safer, is to build a (modified) Pro-stock/sportsman chassis using original suspension and then attach the body. that way you've got a strong frame in case of an accident and the weakness of the body is irrelevant.
Just my .02, no matter what, good luck!
Old 07-06-2003, 09:58 PM
dovaka's Avatar
New Member
this is a 2nd gen and is a subframe 3rd gen are uni body i wouldnt do it to one of those either i do plan on bracing it alot but im also removing alot from the car and replacing it with fiberglass or just leaving it off but as the shell sits right now me and 2 of my friends can pick it up off the ground and move it around
Old 07-10-2003, 09:35 AM
farna's Avatar
Member - AMC/Rambler "guru"
Last wiki edit: AMC V-8s
Wiki Edits: 14
2nd gen is also a unit body. The subframe just supports the front suspension. It's supported by the unit body, the unit body is not supported by the subframe. It's short! The body structure, of which the roof is a big part (think roof trusses, like in a house -- would you cut the braces out of one and expect it to do the job?). Welding the "subframes" together won't be enough (the rear rails are directly part of the unit body). You'll need to build more frame into the car, or use a six point roll bar/cage. Another idea, since you're making a little roadster, is to weld the doors shut with a little extra bracing inside. You're taking the roof off anyway, may as well make it a climb over! That alone will add a substantial amount of rigidity. I plan on doing this to a car -- welded shut doors and a roll bar with six point mounting -- but the unitbody I'm using has continuous rails front to rear anyway.
I've driven plenty of cars welded together as you mention, even a 2nd gen T/A. If done correctly it's not a problem. Apparently there were a lot of hack jobs done in the UK so they made it illegal. Smaller cars aren't as sturdy as bigger US makes either, so it would be harder to do with the smaller ones. You need a good level floor to work from for measuring as well. Cut the windshield posts in the center on both. You may need to put some reinforcement inside the post also, and in the rocker panels as that is the main longitudinal support area.
Old 07-10-2003, 10:02 PM
dovaka's Avatar
New Member
i didnt get into the bracing to much at first because it wasnt really part of my initial question but i did plan on wleding the doors shut and bracing it in there and i was going to weld more bracing in under neath as well as the subframes together and recently ive been considering adding a roll bar sort of like in a ac cobra where it comes up over each person and loops back down but i havent really decided on that yet i jsut know that iam going to adda crap load of bracing into the car once its put back together
Old 07-11-2003, 08:52 PM
Flipper_1938's Avatar
I say go for it. Have you really actually looked to see how few spot welds there are that hold your Camaro together?
You might consider taking the panels apart at the joints (drill out spot welds) and then put the good pieces back together.....use a brass block to back up the hole and do a plug weld.
Or if you are going to cut across and then mig weld, leave a small gap (1/16" ?) so that you get 100% penetration between the panels.
....just my $.02
