Welding on a rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2008, 04:55 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Putting a 95 S10 Posi in my old Stude, but I need to relocate the spring perches and have some random questions.
1. The axel tubes are steel, right?
2. Can I weld on the perches without dismantling the rear end?
3. Should I drain the fluid or replace it with something non flamable?
4. Is warping the housing a big concern?
5. Other than the correct pinon angle, is there anything else?
Old 09-29-2008, 05:47 PM
powerrodsmike's Avatar
Wiki Edits: 161
Tubes are steel
No need to dismantle it. Clean the outside where you are to weld.
No need to drain the fluid, even if you did, there is so much fluid still inside that it's going to smoke no matter what.
If the fluid catches fire, it'll use up the oxygen pretty fast and go out.
Weld in 1/2" long beads, alternate between perches to allow some cooling between welds, and you should not warp it alot. Don't pile up the weld and don't turn up the heat a bunch and you'll be fine.
When I do them like that they only move a little bit. .030" or so at the housing end, not enough to worry about.
Nothing else other than pinion angle.
Later, mikey
BE different....ACT normal.
Old 09-29-2008, 07:34 PM
oldguy829's Avatar
Wiki Edits: 88
welding rear end
Thanks Mikey
Old 09-29-2008, 08:32 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Just for others who plan to do this, I'll add a little about the pinion angle. With the car level, put a protractor on the trans tailshaft. Let's say you read a 3* down-bubble. Rotate the diff housing so that you have a 2* up-bubble on the pinion. This will allow the pinion to line up parallel with the tailshaft under light to moderate power when the pinion gear climbs the ring gear a little while cruising/passing and will lead to a long and happy life for all involved. At least, that's the way I do it for a street ride. For drag racing, you'd want more difference of angle, but that's a different story.
Welding info Kevin45 Body - Exterior 9 08-26-2011 08:09 AM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
68 Camaro Rear end Curtis Thornton Transmission - Rearend 14 03-12-2008 05:19 PM
welding your rear end carrier. NO! bullheimer Hotrodding Basics 16 06-24-2007 02:48 PM
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
