What is this bolt and where can I get another one? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2020, 05:01 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
Someone only installed one of the bolts that holds the steering column to the floorboard. I tried the one bolt that was installed in all the holes and it fit each one without trouble. The problem I'm having is that I can't find this size bolt anywhere, even on the internet. Can someone shed some light on this? I've posted a picture below. I think this would make this bolt a M6-1.75x20, but that doesn't seem to exist anywhere.
Thanks,
Old 01-04-2020, 05:50 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
It's an automotive body bolt and washer that is most likely available at any automotive parts store in your area, such as Autozone, Advance Auto Parts, O'Reilly's Auto Parts, Genuine Auto Parts (NAPA) or others. They will have a bolt and nut section that you can search through.
Since there was only one bolt in the assembly, I might suspect that the other one was stripped out in the floorboard and that's the reason it was missing. You may have to do some surgery or other retro-fitting with another size bolt or even a bolt and nut arrangement.
Old 01-04-2020, 05:53 PM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
wrecking yard.
those are sometimes carried by auto body shops. usually one of the old time mechanics has a bucket of bolts. pulled off wrecked cars.
Old 01-04-2020, 06:07 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
What car does it need to fit?
I found a guy on E Bay for old GM fasteners as I needed some for door panel trim strips and door pull handles on a 64.He had them.
https://www.ebay.com/usr/muscleparts...p2047675.l2559
Fact is stranger than Fiction
Old 01-04-2020, 06:08 PM
LATECH's Avatar
These it ?
https://www.ebay.com/itm/1970-1972-1...oAAOSwRiFcc84L
Old 01-04-2020, 08:36 PM
Vetteman61's Avatar
Well, I found out from a response on another forum. In case this might help someone else, I'll post what I found. This is a sheet metal screw, not a regular bolt. The size is 6.3-1.81 x 20mm. The original GM part# is 11505022. Be careful because it seems some websites have the Incorrect GM part number listed as GM# 11500970.
The Following User Says Thank You to Vetteman61 For This Useful Post:
Bob37pont (01-06-2020)
Old 01-05-2020, 06:23 AM
predator carb guru's Avatar
Mark Goulette
Check on McMaster-Carr...they have tons of stuff like that
Old 01-08-2020, 10:21 AM
PHWOARchild's Avatar
Ace Hardware will have them or something real close.
Old 01-08-2020, 05:02 PM
LATECH's Avatar
The "real close" thing doesnt fly for me. I needed some GM screws for my 64.
I could not find anything that would work correctly for my car.
I found some OE pieces that work exactly like they should.
Nothing like OE stuff
