What Carb for L31 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2017, 03:27 PM
What Carb for L31 ?
Hey Guys, before I spend around 400 dollars on a Carb and choose the wrong one I thought I'd ask for your advice first. Which exact Carb would you recommend? I have an L31 with a performer rpm intake and electric fuel pump that maxes out at 6.5. At this time I only plan on around 300 HP and may do a cam change down the road but nothing crazy.
Thanks guys
Old 05-08-2017, 10:59 AM
This holley carb below is one I have used many times on several different builds over the years from a bone stock 305 my brother had to a stock 350 vortec and for a build making almost 400 hp but I had to upgrade some things since I had a way bigger cam then a mild cam like the vortec comes with.
I also get my carb parts from allcarbs and also below I posted a secondary metering block kit that allows you to get rid of the metering plate which on the 600 holley is about a 65 to 66 jet size and you can't change it but with the metering block you can then have jets on front and the rear side of things and with being able to change jets in the rear side of things you can tune it for what ever your engine will want. For a small block making less then 350 horsepower and running a mild cam this carb can't be beat.
When going to a bigger cam size of 270 degrees duration from seat to seat and [email protected] or more on the intake and exhaust lobes of a cam then you would have to modify it some but that is a whole other tuning guide there but for a mild vortec it would be pretty close out of the box. They are jetted pretty lean on the secondary side of things with the metering plate and I get the metering block kit from all carbs and then install 72 jets on the rear for a starting point and 66 on the front metering block and usually depending on certain things its pretty close within a few sizes up or down.
Holley 0-80457S 600CFM Street Warrior Electric Choke Factory Refurbished 4bbl | eBay
METERING BLOCK CONVERSION WITH TRANSFER TUBE
The Following User Says Thank You to eric32 For This Useful Post:
48PontiacTorpedo (05-08-2017)
Old 05-08-2017, 12:29 PM
IF you can only run a spreadbore carb, then an Edelbrock AVS 650cfm is perfect. If you're not an Edelbrock fan; Holley has a spreadbore carb I think 6210 is the 650cfm version.
If you want to run a squarebore; go to Quickfuel or AED and get a vacuum secondary 650-700cfm carb that fits your budget,choke arrangement and appearance.
The Following User Says Thank You to AutoGear For This Useful Post:
Old 05-09-2017, 10:54 AM
Thanks guys
What carb did you choose and why has it turned out to be the wrong one?
What is the rest of the L31, is it stock but modified for a carb, or have you replaced internal parts like cam, pistons, heads, etc.
So where I'm headed is before you spend more money do the current parts work together or can they be made to work together without spending a ton of money.
Bogie
L31-R how much HP? greasygary Hotrodding Basics 9 04-29-2016 07:13 PM
What intake for L31 ? 48PontiacTorpedo Hotrodding Basics 3 11-19-2015 06:01 PM
lg4 to l31 deadbird101 Engine 8 07-28-2014 12:31 PM
02 l31 5.7 johnstruck Hotrodding Basics 1 11-23-2012 06:50 PM
L31 Vortec Conversion to Carb. Ct Street Rod Engine 10 07-25-2010 06:21 PM
