The "What Did You Work On Today" thread - Page 1017 - Hot Rod Forum : Hotrodders Bulletin Board
  #15241 (permalink)
Old 01-28-2016, 09:48 AM
Guest
Location: in the land of Trolls at least till the san andreas releases the big one
Originally Posted by 496CHEVY3100 View Post
what is this car
its not a batmobile..
The Following 2 Users Say Thank You to 69612 For This Useful Post:
123pugsy (01-28-2016), OneMoreTime (01-28-2016)
  #15242 (permalink)
Old 01-28-2016, 03:43 PM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
I have a friend in Chattanooga that has a Lambo,parts are extremely expensive ,,he had so much problems with his ,he installed a 4.9 engine and transaxle from a cadalliac in the rear of the lambo ,,it is a great driver,,he kept all the running gear intact so if he ever sells it he can reinstall it,,1 good thing he did no cutting or welding to the car he made brackets and everything is Bolt in .
  #15243 (permalink)
Old 01-28-2016, 03:44 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
Originally Posted by waynep712 View Post
i forgot to mention i have been in contact with a chad over at http://lamborghinionly.com/
just looking at the cuts in the sides of the rotor hat section they seem to be designed to pull... and i had that thing smoking hot with my hot air gun..
you can see the first picture for a better look at the puller. today.. i make 2 more adapters... some more grade 8 bolts.. stacks of washers and if i can find it my OTC HUB puller that i use for Dodge tapered axle hubs.
The exploded view certainly seems to indicate the rotor should just "slip" right off...
Did Chad have any tips/advise ? Is it pressed on the hub ?
Maybe you need to remove the hub and put it in a press ? I have a 20 ton press here...
  #15244 (permalink)
Old 01-28-2016, 05:59 PM
put up or shut up
put the first round of primer surfacer on the 69 Camaro. The gaps look pretty solid in primer being how much of a pain in the butt this car has been. I'll post up some pics on the project forum.
Went to Fry's to get everything I need to wire up my custom head light but I saw something there that I should have gotten. I'm thinking I need to punch/drill out tiny holes on this circuit board and feed a tiny piece of metal thru it it that will stick out and make it easier to solder a wire down onto it. I just can't get a wire to stick to that tiny post. I'll look into that nerdy stuff on youtube and see what I find. This headlight planning is a pain in the butt.
  #15245 (permalink)
Old 01-28-2016, 06:26 PM
Brian who have pounded in our heads ,,Saftey,Saftey,Saftey
here is a fine example a little grapic
This is Real Not Photoshopped
https://www.facebook.com/10000800826...22620/?fref=nf
  #15246 (permalink)
Old 01-28-2016, 06:39 PM
Guest
after leaving it hooked up under pull all night.. it had not budged tomorrow.. i have OTC wheel hub puller and 2 more of the coupling nuts with the large head hex nut on the side.. if it won't budge.. i am going to attack the rotor face around the pilot a small groove with the tiny carbide tools i have with my dremel.. i don't plan on going all the way thru.. just cut a bevel and perhaps it will free up. i even threaded the hold down bolt holes with a 3/8-16 tap.. trying to pull it off against the 8 mm holes.
if all else fails i will order up some wilwood rotor hats and rotors.. reman calipers are already on the way. as they are really ugly. that was the owners choice.. i just supplied the part numbers for new shims and noticed a great deal on calipers.
  #15247 (permalink)
Old 01-28-2016, 06:45 PM
Guest
DOH!!!!!!! that won't buff out.
  #15248 (permalink)
Old 01-29-2016, 01:09 PM
Project89's Avatar
checked to see if the camaro would fire up after being outside in -20-25* weather for the last 2 months
much to my surprise it fired right up
  #15249 (permalink)
Old 01-29-2016, 01:49 PM
AirwolfPJ's Avatar
Well, after a 3 day / 2 night stay at the Hospital to get my ticker checked out, I finally made it to the garage. Got the 19" wide rear fenders sanded, the rest of the box cover glassed, filled, and cut for the hinges. And the rear holes for the lights glassed on the inside of the box.
Found out the piano hinge idea wasn't going to work. I would've had to have had too much of a gap with it mounted on the inside. So much for that idea.... Found some SS and chrome hinges on various marine websites at about half of what the Tbucket places get. Same hinge.
Will get some photo's in my build thread this weekend.
  #15250 (permalink)
Old 01-29-2016, 01:55 PM
idrivejunk's Avatar
Grand Prix user
Last journal entry: Last look
To both AirwolfPJ and Project89...
Sounds like its still working fine!
I yanked chrome off a 70 Mustang today. Got off early enough that its 70F so I'm gonna clean up the nasty GTP then get the loud one out before dark.
  #15251 (permalink)
Old 01-29-2016, 04:22 PM
I'm going assume the ticker is at least OK, if they kicked you out !! Hope all is well.
Originally Posted by idrivejunk View Post
T
You know how to hurt a guy posting a temp like that. We barely made it to 30 and that's mild for this time of year here.
I hope the Mustang doesn't turn out like the one I did a couple years ago. It had multiple layers of filler cracking and a "couple soft spots" too.
Photobucket has been down all day, so no pics but long story short, I cut everything off at the firewall, repaired that and built a whole new front from aftermarket parts.
Today, got the '70 SS Chevelle I've owned for 13 years off the storage lift and into the shop. It is now minus the front clip and engine/trans. Be keeping the good stuff I put on it for the "other" '70 SS Chevelle I bought a few weeks back. Gotta get this one trimmed out to sell.
  #15252 (permalink)
Old 01-29-2016, 04:47 PM
idrivejunk's Avatar
Grand Prix user
I don't know how you guys do it in such temps. Today is a fluke here. We can just say that might have been a typo and create plausible denial of said hurt. LOL. BTW you know how to gut punch a Chevelle lover just as good.
If theres such thing as a plastic magnet, its ponycars. They usually have such creative alternatives to welding hidden under the plastic shell. Amazing. See close-up pic below, then cleanse your pallate with this Turquoise Frost 67 Ford cab. Fresh as a daisy, man.
Thats at least a half inch in spots. Who were they kidding? Ha. Here ya go-
vvvv
ID:	271689   Click image for larger version
ID:	271697   Click image for larger version
  #15253 (permalink)
Old 01-29-2016, 05:32 PM
Same floor pans I just put in with the T stamped in them. Did you replace the cab mount below the pan and repair the rusted out kick panels too ?
The Chevelle is rough but very restorable...interested ?...
The Following User Says Thank You to Too Many Projects For This Useful Post:
tech69 (01-29-2016)
  #15254 (permalink)
Old 01-29-2016, 05:46 PM
idrivejunk's Avatar
Grand Prix user
As long as I'm still living in the city, no more home restos for me. I just watch my GP rot and do burnouts more gently as years pass. Its a Chevelle at heart, at least maybe a Monte if not.
Wondered whose name they were trying to spell with that floor. I'd have to dig out pics to see maybe what was done with the floor. It wasn't too bad in the areas you mentioned but the core support was only attached by gravity. I just tore down that truck and didn't have much else to do with that job until the dash shave and bed stuff. May have done some mud or primer on it myself, can't recall. Another guy shaved the cowl vent slots.
  #15255 (permalink)
Old 01-29-2016, 06:15 PM
The '65 I've been restoring needed all that I mentioned plus the lower cowl and door pillars rebuilt from scratch. Then I moved on to the clip. They had a new core support and fenders but the inners were very rotten too and they thought I should hand build those also. I found a pair of very clean originals in CA and they are on their way here now. For the $250 WITH shipping, I can't spend 2 days rebuilding inner fenders...
Link to the build...
https://www.hotrodders.com/forum/1965...ir-409770.html
build thread, projects
« Come On Man! | - »
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
idrivejunk, whinny, brading
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
Increase thread title "preview" time cboy Hotrodders Site News & Problems 16 07-03-2008 08:45 PM
