The "What Did You Work On Today" thread - Page 1404 - Hot Rod Forum : Hotrodders Bulletin Board
  #21046 (permalink)
Old 10-26-2017, 05:26 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
I would be on the phone to the place you bought it from to come take it back and refund my money. It hasn't sat near long enough since you bought it to have the engine seize...
The Following User Says Thank You to Too Many Projects For This Useful Post:
496CHEVY3100 (10-26-2017)
  #21047 (permalink)
Old 10-26-2017, 05:45 PM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
They already have too many problems ,she is a severe diabetic,,and his Kidneys stopped working about two months ago and he is on dialisis,,I would just give them the money and scrap the lift before I would take it back or ask for any money back,, they need the money more than I do,
I will fix the lift just will have more money in it than I planned.
The Following 3 Users Say Thank You to 496CHEVY3100 For This Useful Post:
boothboy (10-27-2017), idrivejunk (10-26-2017), Rip VW (10-27-2017)
  #21048 (permalink)
Old 10-26-2017, 05:48 PM
I thought you bought it from a company, didn't know it was a private party.
  #21049 (permalink)
Old 10-26-2017, 05:52 PM
Yea it was a couple that had a forklift repait shop and had to close it when her mother was diagnoist with dementia and had to move it with them and now her husband is in really bad condition,,,i didn't need it I just bought it to give them some extra money, every think will work outt
  #21050 (permalink)
Old 10-26-2017, 05:57 PM
Good luck with it David. Fingers crossed.
You guys are all doing a lot more exciting things than I am. I did get my shroud corners cut out and fitted.
John
The Following 3 Users Say Thank You to John long For This Useful Post:
123pugsy (10-26-2017), idrivejunk (10-26-2017), Rip VW (10-27-2017)
  #21051 (permalink)
Old 10-26-2017, 06:06 PM
Lots of work involved when you can just order it,,i know I had same problems ,just not near as many parts to make as you,,front hood panel ,,inner fenders ,firewall and interior panel to replace gas tank is all I had ,they are big panels and fairly easy to work,,the small finish work seems to be the hardest for me.
I wish I had the hose blowing of on camera ,,it looked like the three stooges ,without mo and larry.
John long (10-26-2017), Rip VW (10-27-2017), Too Many Projects (10-27-2017)
  #21052 (permalink)
Old 10-26-2017, 06:12 PM
couple of before and after
mine are just straight forward simple stuff,,i could never do what you have done,,you make metal work look like artwork.
ID:	384794   Click image for larger version
ID:	384810   Click image for larger version
ID:	384818   Click image for larger version
ID:	384826   Click image for larger version
ID:	384866   Click image for larger version
The Following 4 Users Say Thank You to 496CHEVY3100 For This Useful Post:
123pugsy (10-26-2017), adantessr (10-26-2017), idrivejunk (10-26-2017), Rip VW (10-27-2017)
  #21053 (permalink)
Old 10-26-2017, 06:19 PM
Wow, You put a lot of work into that rear cab wall. I like it...a lot! :
John
The Following User Says Thank You to John long For This Useful Post:
  #21054 (permalink)
Old 10-26-2017, 06:28 PM
That is one of the downfalls of building a custom,,we spend Days and sometime weeks making something Just like we want it and no one ever sees it or realize the work that was done..But We know.
  #21055 (permalink)
Old 10-26-2017, 06:38 PM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I worked on the forklift for a while today,,still wont turn after soaking overnight in PB Blaster,,so today I poured about a half of a quart of 10 wt oil in the cylinders let soak about 10 minutes and then hooked my leak down tester hose adapter ,screwed it in plug hole and applied 40 psi air pressure to see if I cam blow some oil past the rings and loosen yhem ,then I raised air pressure to 100 Psi and turned on valve,,tomorrow after I get the oil cleaned up from the floor and my IPhone where hose blew apart and covered everything on that corner of the shop,,had to quit for today and clean my phone and myself from the hydraulic oil,,,well there is always tomorrow..
Yes I was filming it but my camera turned over and all I got was the light which everyone has already seen,,
if I can load it I have a very short video of what I am trying to do,
If it was running, no reason it should be seized. Maybe a dropped valve binding it up tight?
  #21056 (permalink)
Old 10-26-2017, 07:14 PM
idrivejunk's Avatar
Grand Prix user
Last journal entry: Last look
Time to chop.
The Following User Says Thank You to idrivejunk For This Useful Post:
Rip VW (10-27-2017)
  #21057 (permalink)
Old 10-26-2017, 07:34 PM
Originally Posted by idrivejunk View Post
Time to chop.
OK, You now have our attention!
John
The Following 2 Users Say Thank You to John long For This Useful Post:
  #21058 (permalink)
Old 10-26-2017, 07:37 PM
[QUOTE=123pugsy;4337234]If it was running, no reason it should be seized. Maybe a dropped valve binding it up tight?[/QUOT
It could be but don't think it is it wont turn either direction a dropped valve it should rock a little one direction or the other,,i personally thik it has been sitting longer than what they told me,,they had a big stack of pallets where they sold machinery out of the shop ( supposed ) been only 2-3 months since the moved the pallets ,,don't sound right to me, I think a lot longer,
the starter was bad and battery dead when I bought it so I didn't hear it run ,just took their word,
  #21059 (permalink)
Old 10-26-2017, 08:12 PM
idrivejunk's Avatar
Grand Prix user
John
Oh crap! Must run hide! Hey so do you guys think I'll be OK removing the braces bolted to the door hinge areas to make way for me and a sawzall in there? There won't be anything horizontal left except rockers and inners. But I figure it will probably be OK until it goes back on the roto.
  #21060 (permalink)
Old 10-26-2017, 08:47 PM
idrivejunk's Avatar
Grand Prix user
Sorry These...
build thread, projects
« Come On Man! | - »
Currently Active Users Viewing This Thread: 10 (3 members and 7 guests)
496CHEVY3100, MARTINSR, cozwurth
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
Increase thread title "preview" time cboy Hotrodders Site News & Problems 16 07-03-2008 08:45 PM
