The "What Did You Work On Today" thread - Page 1414 - Hot Rod Forum : Hotrodders Bulletin Board
  #21196 (permalink)
Old 11-06-2017, 09:04 PM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
I have been wondering if I could replace at least the center carg on my BBC with a throttle body FI ,,it is 496 cu in so 1 might not be enough,,i would like to leave front and rear carb if possible , because they can be seen even with the air filter on,
ID:	386642   Click image for larger version
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
boothboy (11-07-2017)
  #21197 (permalink)
Old 11-07-2017, 06:04 AM
Fast 2.0 could support 1000 plus hp. But you?d have to change entire intake. I was impressed again went out this morning no throttle pushes nothing 383 fired right up. It does do a presquirt.
  #21198 (permalink)
Old 11-07-2017, 06:07 AM
It was a little expensive with inline regulated pump but from my understanding standard in tank pump can also be regulated down to 43 psi
  #21199 (permalink)
Old 11-07-2017, 06:36 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
Inline corvette regulator right back at the tank with return.
  #21200 (permalink)
Old 11-08-2017, 12:06 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Got ends made for the 59 Pontiac job's rear trunk pan extension. Just screwed in place for support at this moment. Finishing up welding some cowl bottom repairs today also. Somebody held a tire under it and said we need tubs that are closer together than the trunk hinges... So it's back to patching until decisions are made.
The Following 2 Users Say Thank You to idrivejunk For This Useful Post:
123pugsy (11-08-2017), John long (11-08-2017)
  #21201 (permalink)
Old 11-08-2017, 09:32 PM
I got out there after dinner and a long day, not for my truck but to start straightening a Nailhead Oil pan for my brother to put in his 39. It looks like there is still a big buckle, I swear I didn't see that until looking at the photo. If it's really there I'll take care of it tomorrow. Can't wait to drive that 39 of his.
ID:	387026   Click image for larger version
  #21202 (permalink)
Old 11-08-2017, 10:36 PM
Do you think he might have made clearance for cross member or steering rods ,is why the pan is recessed.
  #21203 (permalink)
Old 11-09-2017, 09:24 AM
It wasn't "recessed" it was smashed.
The Following User Says Thank You to MARTINSR For This Useful Post:
496CHEVY3100 (11-09-2017)
  #21204 (permalink)
Old 11-09-2017, 11:42 AM
idrivejunk's Avatar
Grand Prix User
Here's the '59 cowl plenum / fender area zapped and patched up, and a better look at the rear trunk pan extension patches shown in place last post. Coatings drying on those and the trunk braces to be reused right now, welding that up after a sandwich.
ID:	387058   Click image for larger version
The Following User Says Thank You to idrivejunk For This Useful Post:
Too Many Projects (11-09-2017)
  #21205 (permalink)
Old 11-09-2017, 05:06 PM
Not much to show around here, unless you want to see pics of how well my yard vac works... Vacuumed all the leaves and then mowed the entire yard while it was a balmy 38. Today's high is 19...
The painter called yesterday and I am picking up the body shell Sunday to put back on the chassis. The chassis is buried under 5-6 weeks of "stuff", so I started looking at digging it out today. Well, of course, moving all the crap on and around it involves "sequences" of movements that took up most of the day finding a place for all the "stuff", other than on or around the chassis...
1 tire on my rollback blew out returning the Blue Chevelle a week ago too. It had a cut in the sidewall that I patched, but it let go, so I ordered 2 more tires that came today. Tomorrow's project is to get them on and then get back to work blasting parts for the Chevelle and continuing to get the chassis free.
I did mount and balance the pie crust cheaters today, but I'm calling tomorrow to see about exchanging one that has a huge "counterbalance" patch in it. It took 8 ounces to balance and I'm afraid it will hop at speed.
The Following 2 Users Say Thank You to Too Many Projects For This Useful Post:
idrivejunk (11-09-2017), Rip VW (11-09-2017)
  #21206 (permalink)
Old 11-09-2017, 05:28 PM
idrivejunk's Avatar
Grand Prix User
Dang Mitch, 8 oz, eh? Maybe thats pie for the course with those. But mmm, pie.
19 degrees sux man. Stick close to the warm one.
I almost made it but was grinding as I went, in the interest of heat management. Still have to weld up the right end with it's big gap and all. I can see in the pics that it could use some prettying up. On the inside, those upright corner braces were just stitched to the pan. They were awful shaggy at the bottom so once I put the pan in I'll decide whether that will do now or whether an attaching strip is needed.
ID:	387138   Click image for larger version
ID:	387146   Click image for larger version
  #21207 (permalink)
Old 11-09-2017, 05:52 PM
Not getting much done,seems the 1990 had a different floorpan than an 1988 after getting my paint complete ,I bought a used seat from a 1990 single cab and when I tried to install them brackets are wrong ,I had a solid bench and bought a 60/40 ,,the drivers side fits original bolt holes fine ,but passengers side at outside fits ,but the center sits about 4 in higher than drivers side,,i am trying to find a set of original buckets and console,,i have a set from a 89 SS454 Silverado but they are leather and I want cloth,,
!st is what I have 2nd is what I want,
someday I might to clean out my shop some,
ID:	387178   Click image for larger version
  #21208 (permalink)
Old 11-10-2017, 02:58 PM
cozwurth's Avatar
Last journal entry: Vinyl top carnage...
I spent most of the day today and a good part of yesterday cleaning up in the shop. I'm trying to get things situated so that I can get all of the woodworking stuff out of hiding. I'll be picking up the new motor for the compressor tomorrow since Tractor Supply is giving active duty and veterans 15% off for veteran's day. That should come close to covering the 3 year service plan if I decide to do that.
Dave
  #21209 (permalink)
Old 11-10-2017, 03:16 PM
idrivejunk's Avatar
Grand Prix User
Cat tail done, so we don't have to look at that any more.
This is something I had nothing to do with but those 60s colors look so juicy in modern pigments... and Pontiacs are exciting.
123pugsy (11-10-2017), Too Many Projects (11-10-2017)
  #21210 (permalink)
Old 11-10-2017, 04:55 PM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Finally got all the tiles in and sealed/enhanced.
Just need to caulk and screw in the outlets.
The Following 4 Users Say Thank You to 123pugsy For This Useful Post:
idrivejunk (11-10-2017), Rip VW (11-10-2017), timothale (11-10-2017), Too Many Projects (11-10-2017)
build thread, projects
« Trivia thread | - »
Currently Active Users Viewing This Thread: 12 (1 members and 11 guests)
idrivejunk
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
Increase thread title "preview" time cboy Hotrodders Site Problems 16 07-03-2008 08:45 PM
