The "What Did You Work On Today" thread - Page 1429 - Hot Rod Forum : Hotrodders Bulletin Board
  #21421 (permalink)
Old 12-04-2017, 01:27 AM
Originally Posted by Dave57210 View Post
Today I didn't do anything car-related
Got SOME of the Christmas lights up on the front of the house and "gift-wrapped" (put winter covers on) the travel trailers
Yes Christmas lights... Went looking for set of Icicle Lights locally couldn't find any.
Worked on ... Helped a customer R&R elect fuel Pump in his 86 Coupe Deville. In dis-assembly found the rubber fuel line from the pump to the steel line had the consistency of a molten gummy bear.
Just a reminder and wake up call for what out current fuels and additives are doing to the fuel lines in our cars. This has a lot to do with all the cars catching fire on the highway.
  #21422 (permalink)
Old 12-04-2017, 01:32 AM
bullheimer's Avatar
NEVER use credit cards!
49 chev How does a heat gun restore color?
junk, what year is that poncho? 59? i love them whatever it is. very batmobilesk.
today i finally had a chance to mount my radiator, (without cookie sheet shroud), in my truck. to bad i bought the wrong anti freeze and still have to wire it. going to wire it to the same relay that i put in for my electric fuel pump. although i plan to someday wire it to my thermostat. but then i would have to buy a different relay so maybe if it runs okay on cold days i might not.
also changed out my water neck. other one kept leaking. ran out of gas friday in the buick cause my two year old ebay gas gauge quit working. still have to fix that and while the instrument panel is out for the umpteenth time, try again to repair the p.c. so all the lights work again. at least half are working this time, which means i can eliminate the plug connector. go Hawks!
  #21423 (permalink)
Old 12-04-2017, 04:18 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by 496CHEVY3100 View Post
While working on the truck I found a computer that I thought was for the radio,,the one for the radio is miunted just above the sterring column but it is there,,
Is it possible for the truck to run without the computer ,,I think I left it out when replacing heater core and evaporator core
Nope....... why, is Christine running now w/o the ECM?
  #21424 (permalink)
Old 12-04-2017, 06:36 AM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
bullheimer's Photo Album
bullheimer's Project Journal
I really don't know,i saw on a tv show Gears I think, and tried it,amd it works onhard plastic ,,DO NOT use on vinyl I will cause it to get hard and wrinkle,,also will burn carpet so don't get close to it,,,i had several sets of old door panels so I tried it on them first...I have been doing it about 5 years and had good results,,i did a video but don't have sound I will try to post it,,
when it gets hot it causes an oily film to come to the top and will have some streaks,you will have to go over it 2 or 4 times to get it uniform.
The Following 3 Users Say Thank You to 496CHEVY3100 For This Useful Post:
adantessr (12-04-2017), Foperfoauto (12-04-2017), John long (12-04-2017)
  #21425 (permalink)
Old 12-04-2017, 01:57 PM
The truck runs fine shifts good every thing works,,but after warn it sounds like timing might be a little high ,,starter drags for a couple seconds then turns and starts good,,
  #21426 (permalink)
Old 12-04-2017, 02:21 PM
123pugsy's Avatar
Wiki Edits: 29
WT?
Runs without the ECM?
I was certain injectors are pulsed by the computer. Maybe I need to read up some more?
  #21427 (permalink)
Old 12-04-2017, 05:15 PM
WT?
i thought is was Impossible ,but we have had this truck since New and the ecm has never been replaced,,i had the entire dash and copllete wiring harness out during the summer ,before it went into body shop,,it was located behind the glovebox when i was replacing heater core and evaporator but am ( almost ) sure i put it back,, i guess i will pull glove box out and check what is going on.
  #21428 (permalink)
Old 12-04-2017, 06:20 PM
Went to town today for some parts,and saw they were pulling some of James my late friends cars out for the auction ,Thursday - Saturday,,these are suppose to be an absolute sale,,( no reserve ) about 65 cars
the building in last picture has about 40 cars inside mostly from the 30s and 40s.
,the other cars about 60 more mostly 55,56,57 chevys of which 16 are convertibles will sell later but with a reserve ,,also 5 or 6 Baby birds,are in another warehouse in different location.
ID:	391778   Click image for larger version
ID:	391786   Click image for larger version
ID:	391794   Click image for larger version
ID:	391802   Click image for larger version
ID:	391818   Click image for larger version
The Following 7 Users Say Thank You to 496CHEVY3100 For This Useful Post:
123pugsy (12-05-2017), adantessr (12-04-2017), Foperfoauto (12-04-2017), idrivejunk (12-05-2017), John long (12-04-2017), Rip VW (12-04-2017), Too Many Projects (12-05-2017)
  #21429 (permalink)
Old 12-04-2017, 06:43 PM
Got the 305 on the stand and finish ripping it down.
Plan on this one is 4-bolt Main 60 over.
Crank is on order.
  #21430 (permalink)
Old 12-04-2017, 06:45 PM
On the third picture ,does anyone know what the car is between the Nash and the 58 Ranchero. the Big roadster typr car,
  #21431 (permalink)
Old 12-04-2017, 06:54 PM
I'm not greedy. I just want the '34 Dodge, '40 Ford, '50 Ford and the A model.
I have most of my holes drilled and the front end mached up on the stand. The upper radiator support is not "settling down" quite far enough for the upper rubber saddle to snug up so I have just a bit more tweeking to do. I am getting really close though.
John
The Following 4 Users Say Thank You to John long For This Useful Post:
123pugsy (12-05-2017), idrivejunk (12-05-2017), Rip VW (12-04-2017), Too Many Projects (12-05-2017)
  #21432 (permalink)
Old 12-04-2017, 07:04 PM
Hmmmm, I can't tell what it is but I want it too.
John
  #21433 (permalink)
Old 12-04-2017, 07:05 PM
John
zoom in the third picture,,all the 56 and 56 Ford convertibles,,the Black convertinle is Aunt beas car from Andy griffin show,,her personal car with All the documentsmmit is VICE but dirty now from sitting in building,,interior is imaculate red and white.the better cars are on the left side of the building
The cradle looks Great,
  #21434 (permalink)
Old 12-04-2017, 07:15 PM
Here is you another A model
I don't know if you need any thing for the 36 or not but he has Tons of early ford NOS parts still in wrappers from 40 back no newer stuff
I ma talking tractor trailor loads
  #21435 (permalink)
Old 12-04-2017, 07:18 PM
Man, your killing me. So many wants and so few years left to play with them.
A '56 Ford or Mercury convertible would be about perfect for Christmas though.....Now, where did I put Santa's email address?
John
build thread, projects
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
Increase thread title "preview" time cboy Hotrodders Site News & Problems 16 07-03-2008 08:45 PM
