The "What Did You Work On Today" thread - Page 1431 - Hot Rod Forum : Hotrodders Bulletin Board
  #21451 (permalink)
Old 12-05-2017, 08:10 PM
Originally Posted by idrivejunk View Post
Thanks. I will probably be tapping around up there every time it bothers me, up until filler time. I just really couldn't get it to do what I wanted until it was all together with a full seal in place. It responded much better to the slapper with some shrinking done and lid latched. Looks better all around. The sander technique sufficiently heated maybe a two inch spot at a time.
You do some awesome stuff!
The Following User Says Thank You to MARTINSR For This Useful Post:
idrivejunk (12-05-2017)
  #21452 (permalink)
Old 12-05-2017, 08:11 PM
Woopee! Moving on to building the chassis........Time to get the body back out of the way.
John
WHOOOO HOOOOOO! WHOOOOO HOOOOOOO!
  #21453 (permalink)
Old 12-05-2017, 08:14 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition
Wiki Edits: 3
Originally Posted by Too Many Projects View Post
You're going to have a 305 block converted to 4 bolt main ??? um, why ? at .060, isn't that close to a stock bore 350 ?
Pretty sure the 305 bore is only 3.750 , or there about. Not enough cylinder wall thickness to bore to 4.00. 283 on the other hand was 3.875 bore. You could take it out to 4.00 but not enough room to swing a 327 crank. I know, I tried it 40 years ago. Hence the 302 chevy. 327 bore with 283 crank. 350 and 305 have same stroke. .250 difference in bore.
  #21454 (permalink)
Old 12-05-2017, 08:30 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Thank you sir, and I am just glad to have this kind of work because I kin only do whut I git asked fer. I wondered if theres anything to tell about your young-un's V8 project.
Can't count how many times I have referenced this pic. I need to take a new one from the same angle for comparison but you can spot the original crown here. That panel went ape nuts when I cut the front edge. I breathed a sigh of relief when I saw the lid front edge level out better with a complete seal in place. The seal is still untrimmed and hangs out making it hard to shut especially since the trunk has no pan and is floppy. And that has it not quite going down all the way in back. Y'know. The car had nice gaps and I am just trying not to ruin it!
  #21455 (permalink)
Old 12-05-2017, 08:40 PM
idrivejunk's Avatar
Grand Prix User
John
John, if your build is a quarter mile four speed pass.... I think you just chirped third gear.
  #21456 (permalink)
Old 12-05-2017, 08:49 PM
My Young-uns project is going very slow.
  #21457 (permalink)
Old 12-05-2017, 08:52 PM
He really does! To build the cars he builds in a restoration shop where productivity is a must is just amazing!
You got that right
You know maybe, just maybe, I'll get to take a picture of this thing in the driveway next summer!
John
The Following 2 Users Say Thank You to John long For This Useful Post:
adantessr (12-05-2017), idrivejunk (12-05-2017)
  #21458 (permalink)
Old 12-05-2017, 10:39 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
John
No maybe about it, get it moving under it's own power over the winter...
I need that fancy roto next year for my '70 Chevelle...
  #21459 (permalink)
Old 12-06-2017, 12:39 PM
idrivejunk's Avatar
Grand Prix User
Theres Pokey the Stick
Footloose Jr. got new metal for that 53 Chevy truck job today. I am still messing with body mounts. Getting a 1-1/8" hole in 3/16" metal with a unibit is wearing out the drill press elbow.
ID:	392242   Click image for larger version
ID:	392250   Click image for larger version
ID:	392258   Click image for larger version
The Following User Says Thank You to idrivejunk For This Useful Post:
123pugsy (12-06-2017)
  #21460 (permalink)
Old 12-06-2017, 12:55 PM
Yup, hadn't used Pokey on here for a while, so had to let him out to play.
About 1 of those holes with a unibit would have me using the plasma. Draw a circle with a socket and go to it..
Maybe a hole saw would be less tiring too..
The Following User Says Thank You to Too Many Projects For This Useful Post:
idrivejunk (12-06-2017)
  #21461 (permalink)
Old 12-06-2017, 02:45 PM
The plasma cutter is the berries for that sort of thing. Generally, I make pattern that allows me to trace the inside so a slip doesn't ruin the part.
AE: a 1 1/2 inch pattern hole to cut out a 1 1/8 hole in my stock. PVC, 1/4"plywood, etc, etc makes a good pattern for my plasma.
John
  #21462 (permalink)
Old 12-06-2017, 05:23 PM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Got the table stained...phew....was really worried about this step.
The color is actually a bit darker than the pics.
ID:	392370   Click image for larger version
The Following 4 Users Say Thank You to 123pugsy For This Useful Post:
adantessr (12-06-2017), idrivejunk (12-06-2017), John long (12-06-2017), Rip VW (12-06-2017)
  #21463 (permalink)
Old 12-06-2017, 05:24 PM
idrivejunk's Avatar
Grand Prix User
No gotta holesaw or plasma cutter... theres just a couple dull steps on my big stepped bit. I shouldn't have called it a unibit, its not that. I used a burr to get past the dull steps. There is one more to go but I set myself back making changes to the first pair and stuff. Learning! The body is down on all but tbe middle psir of mounts right now and so far so good.
The Following 3 Users Say Thank You to idrivejunk For This Useful Post:
CrashFarmer2 (12-07-2017), John long (12-06-2017), Rip VW (12-06-2017)
  #21464 (permalink)
Old 12-06-2017, 05:27 PM
idrivejunk's Avatar
Grand Prix User
Nice! That color looks much better.
  #21465 (permalink)
Old 12-06-2017, 05:33 PM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
Already spoken for,,,lol..
build thread, projects
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
