The "What Did You Work On Today" thread - Page 1579 - Hot Rod Forum : Hotrodders Bulletin Board
  #23671 (permalink)
Old 04-21-2018, 09:38 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
We, finally, got a real spring day today...60 and a slight breeze. The wife and I spent 4 hours cutting down buckthorn trees in the woods behind the house. Then we sat on the porch swing and watched the snow melt out in the front yard. Well, about 15 minutes of that and we were walking around the front, looking at tree limbs that need trimming out there. We also have a Maple tree that we put weed block and mulch around about 10 years ago. Maples grow wider at the bottom and the roots start to surface. The fabric was up on the trunk at about a 45 angle from all the growth and the mulch had turned to soil, so we ripped the fabric up and just put 4" of mulch around the base. Looks way better than it has for a few years.
Then I got the '38 out of the storage side of the shop and we went to dinner. We just got done watching a Netflix movie and are close to turning in for the day. It was a GREAT day and very productive.
The Following 4 Users Say Thank You to Too Many Projects For This Useful Post:
123pugsy (04-22-2018), cozwurth (04-22-2018), Gearhead Poppa (04-22-2018), idrivejunk (04-21-2018)
  #23672 (permalink)
Old 04-21-2018, 09:40 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Originally Posted by Project89 View Post
this is the shoulder i destroyed about 5 years ago , thats why its so bad this time , so ive got about 6-9 months before my shoulder is useable , figure another 4-6 months to build it back up , and a whole nother year or more before i can ride back at my full skill level again
Dang. It. Usable at all sounds good to me. Will they do a shoulder replacement eventually, you think? Those joint replacements they do now seem to work mighty well. But those are probably more for wear than damage. Your poor tissues other than bone gotta be a mess. Just hold still and ride it out, pardon the pun. Think of the drifting mishaps you may have avoided.
  #23673 (permalink)
Old 04-21-2018, 09:54 PM
I pretty much got the '53 ready to prime the cowl/firewall. I had to shorten the front of both rockers, finish grinding the spring hood brackets. i sanded the bottoms of the rockers also and masked it off.
Should be able to shoot it Monday or Tuesday with a little luck.
The Following 5 Users Say Thank You to John long For This Useful Post:
123pugsy (04-22-2018), 496CHEVY3100 (04-22-2018), Gearhead Poppa (04-22-2018), idrivejunk (04-21-2018), MARTINSR (04-21-2018)
  #23674 (permalink)
Old 04-21-2018, 10:14 PM
Project89's Avatar
this will only slow me down for minimal time , as soon as i can stand to be back on a bike again ill be out there riding again
atleast i got a nice ride in 2 weeks ago
my big bike is currently blown up
broke all the valve springs , its going back together with a 14-1 cr piston , titainium valves , new springs , licks retainers , cams, and a race port head, i had a low compression 10.5-1 piston in it this year , big overbore of course
if u think valve trains are expensive for a car try a bike
600$ for cams
400-450$ for 4 valves
100$ for locks and retianers
and 115$ for valve springs
The Following 3 Users Say Thank You to Project89 For This Useful Post:
123pugsy (04-22-2018), Gearhead Poppa (04-22-2018), idrivejunk (04-21-2018)
  #23675 (permalink)
Old 04-21-2018, 10:45 PM
Didn't get a bunch done, but I got something done. I cut and fit the left inside windshield frame, screwed in ready for welding tomorrow.
The Following User Says Thank You to MARTINSR For This Useful Post:
  #23676 (permalink)
Old 04-21-2018, 10:49 PM
Rolled 2 coats of primer onto my rig. Putting on 4 coats of Hammered silver paint on in 8 hours. Not doing body work. I will get parts then do the thing right. But for now I just want the thing one color.
From this.
To this.
The Following 3 Users Say Thank You to cerial For This Useful Post:
123pugsy (04-22-2018), Gearhead Poppa (04-22-2018), idrivejunk (04-22-2018)
  #23677 (permalink)
Old 04-22-2018, 08:33 AM
cozwurth's Avatar
Last journal entry: Vinyl top carnage...
Yesterday I finished up welding the spring brackets for my trailer onto the channels. Since the trailer frame is round tubing, I welded the spring perches to a length of channel, and will then weld that to the frame. That will also let me adjust the position easily to get it 'squared'. Once my oxygen regulator comes in I can get the hot wrench working again to cut the axles off of the frame.
Dave
The Following 4 Users Say Thank You to cozwurth For This Useful Post:
123pugsy (04-22-2018), Gearhead Poppa (04-22-2018), idrivejunk (04-22-2018), MARTINSR (04-22-2018)
  #23678 (permalink)
Old 04-22-2018, 09:24 AM
idrivejunk's Avatar
Grand Prix User
This is what I was working on Friday. The one piece I'll probably be less than satisfied with. The driveshaft tunnel I made has the center hump not quite centered so this part has to look a bit crooked. I made the pattern as usual by outlining one side then folding it over in the middle and thats when I knew I was in trouble. It won't be as bad after fine tuning but boy does it look whopperjawed in pics. Not real proud of that but the rest should make up for it, and I'll be on cloud nine once the footwells are in for good. In the pic you can see the side extensions where those will connect now with a simple overlap.
While I'm at it, heres the GP with small tires too. I'll get used to it. Brakes work nice with just one tire size difference from front to rear.
ID:	420713   Click image for larger version
ID:	420721   Click image for larger version
The Following 2 Users Say Thank You to idrivejunk For This Useful Post:
Gearhead Poppa (04-22-2018), MARTINSR (04-22-2018)
  #23679 (permalink)
Old 04-22-2018, 10:50 AM
idrivejunk's Avatar
Grand Prix User
Boy did I ever get in trouble with Ms. Grape for posting that. Told me I might as well have showed her passed out in front of the TV drooling in a bowl of tater chips with curlers in her hair. Woops. That angle does make her butt look big. Here she is fully awake, bright eyed and bushy tailed, seated amongst complimentary flowers albeit on a dreary day. She said the bank entrance shot lends an air of dignity and affluence and what-not. Showed her that post when we went for tasty AM chow just now, and she durn near made a scene. She insisted I march straight home and post these pictures right this minute! I sure am crazy about her even after all these years but I hope she don't ping my dome with a rolling pin later. I believe she was concerned what Marge and Precious might think of her. She liked cerial's flower box though. We wondered if theres a cave in that hill.
Gearhead Poppa (04-22-2018), whinny (04-22-2018)
  #23680 (permalink)
Old 04-22-2018, 12:51 PM
Seems you really only need 1 panel for the box... a better, southern box...
  #23681 (permalink)
Old 04-22-2018, 02:12 PM
idrivejunk's Avatar
Grand Prix User
Aren't 67-87 beds bolt-together? I never see bedsides swapped out on them but they look bolt on.
I was just teasing about the ballast pile and want to see the silver. One color is already looking better.
  #23682 (permalink)
Old 04-22-2018, 02:30 PM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
73-87 bolt together for sure.
One weld at the rear only to keep the box side standing vertical.
The Following User Says Thank You to 123pugsy For This Useful Post:
  #23683 (permalink)
Old 04-22-2018, 03:15 PM
bullheimer's Avatar
NEVER use credit cards!
yesterday or day before, pulled alt, p/s, hoses, ex mans, intake bolts and dist off my truck, today planning on getting the intake and heads off. yeah, i'm slow. i know this and dont care. i never drive this thing anyway. need the guides replaced cause it smokes on start up. last valve job i just had them knurl the guides. didn't know that was a short term fix at the time
The Following User Says Thank You to bullheimer For This Useful Post:
  #23684 (permalink)
Old 04-22-2018, 03:24 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Box holds water real good. One good thing the cowboys did was to seal it off nicely.
Until I come along with my drill that is......
Tonneau almost done..need to install the shocks and latches.
ID:	420833   Click image for larger version
ID:	420841   Click image for larger version
ID:	420849   Click image for larger version
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
496CHEVY3100 (04-22-2018), idrivejunk (04-22-2018)
  #23685 (permalink)
Old 04-22-2018, 07:17 PM
Got the drivers inside window moulding welded and finished ready for chrome.
The drivers side is all done, turned the cab around (which was more work than the welding) so I can finish the last few things on the passenger side.
ID:	421009   Click image for larger version
The Following 3 Users Say Thank You to MARTINSR For This Useful Post:
123pugsy (04-23-2018), idrivejunk (04-22-2018), John long (04-22-2018)
build thread, projects
Currently Active Users Viewing This Thread: 10 (2 members and 8 guests)
John long, luvbuildingcars
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
