The "What Did You Work On Today" thread - Page 1643 - Hot Rod Forum : Hotrodders Bulletin Board
  #24631 (permalink)
Old 06-20-2018, 06:32 PM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Pulled the water pump today. I figured this is the only devise that would cause the fan clutch (3 different ones) to work intermittently.
It looks brand new but the shaft seems a bit "jittery" as it's turned slowly.
Is this reverse rotation?....... anyone?...................Beuller....?
  #24632 (permalink)
Old 06-20-2018, 06:52 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
Originally Posted by 496CHEVY3100 View Post
I remember you saying you bought one,i like the look of the old gassers ,some go on extreme especially in the rear,, personally i like the rear fenders radiused and the front with about a 4 in drop axle so that raises the frpnt 4-6 inches And natuarlly Bigs and littles..the package is sceduled for Sat delivery,,i will pm you the tracking number.
since i missed the frame i dont know yet which way i will go .
'55 has a good frame, first year for the C channel perimeter, isn't it ? Get an MII conversion with power r&p and you're good to go.
  #24633 (permalink)
Old 06-20-2018, 07:25 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Looks like I'll require at least one more nightmarish upside down re-re-re-rerouted attempt at making a fuel line from pump to carb. The hard line isn't loose but camera says it rubbed. This last $22 fuel pump has insane hose orientation that puts the flared fitting in an impenetrable cage. With the pump installed the fitting can't be reached.
Last time I unbent the top half of the line enough to allow contortionist maneuvers around the steering to attach line to partially installed pump. Its a nonsensical, typical IDJ-ism where any small thing takes giant effort just to sidestep. Workarounds are my way of life, lol. The engine is set awful low and far back in a 69 G body so the pump is almost over the xmember.
I just spent a half hour finding a spot for two wrenches and confirmed the fitting is tight (raining a bit yay, better than sun though), then another six five minuteses trying to scrub off the evidence. Stuck the phone under it for a quick pic and now I see the clean spot. Either the metal lines rubbed through or that hose clamp backed off. Didn't check that, gas was dripping about a drop a second off the hard line bend this morning. Neato stuff for the weekend.
The Following User Says Thank You to idrivejunk For This Useful Post:
123pugsy (06-21-2018)
  #24634 (permalink)
Old 06-20-2018, 08:06 PM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
YES blades are backwards, the flat side of the blade is on wrong side,,it will still circulate water just not near enough.
edit,,https://www.bing.com/videos/search?q...0F22&FORM=VIRE
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
  #24635 (permalink)
Old 06-20-2018, 08:16 PM
yes all 55 built in Ohio had the seamless frame ( so called California frame,),,i have 2 Corvetts i can use for conversion,,but both are running driving cars didnt want to take them apart,,if i could have gotten the frame from Jim it would have been ideal ,C4 already installed ,R&P installed and C3 rear whick is 1in narrower on eack side,,he sold it for $5000,
  #24636 (permalink)
Old 06-20-2018, 08:28 PM
I have tried 3 times,,so it might double post..removed clip from 55 today the fenders ,iner fenders and hood are very usable,,cant say the same for the Doors,i got my 5 minutes in today ,,only problem it too; me 2 hours,,
ID:	431722   Click image for larger version
ID:	431730   Click image for larger version
ID:	431738   Click image for larger version
ID:	431746   Click image for larger version
The Following 4 Users Say Thank You to 496CHEVY3100 For This Useful Post:
123pugsy (06-21-2018), idrivejunk (06-21-2018), John long (06-21-2018), Rip VW (06-21-2018)
  #24637 (permalink)
Old 06-20-2018, 08:52 PM
Does anyone know what this horseshoe mount fits,,the 4 holes align with the 4 on a V8 chevy but the to lower on the saddle is not even close to the studs in the frame..
Had to quit fir the day tore my toe nail off ,which would not be a big deal ,,but I am a diabetic and it could be a Big problem especially with the blood thinners I am having to take Infection is a big deal so I had to come in and take care of it,,but I am tired so I will just quit for the night.
ID:	431778   Click image for larger version
ID:	431786   Click image for larger version
  #24638 (permalink)
Before we decide if that is a standard or reverse pump. How about a drawing of how the belts turn the pump? Makes a difference. Serpentine or V?
BB
The Following User Says Thank You to boothboy For This Useful Post:
  #24639 (permalink)
Old 06-20-2018, 09:36 PM
BB
They are v belts. From what I've read, that impeller will work. Many rebuilders use it universally to push water both ways. The flat side doesn't move the coolant as well as if the angled side was doing the pushing.
  #24640 (permalink)
Old 06-20-2018, 10:15 PM
I went back to your video you posted a couple weeks ago,,your fan is turning clockwise as it should,,that pump is clearly set up for counterclockwise,,it is hard to tell from the video ,but i THINK your fan blades are pushing air instead of pulling air,, try holding something about a foot in front of the grill,,Flame smoke etc,,and see if it pulls the smoke thru the grill,,my truck pulls enough air to put out a match,,
  #24641 (permalink)
Old 06-21-2018, 12:33 AM
bullheimer's Avatar
NEVER use credit cards!
i think i saw that same problem with a v8 bmw a few months back. i have no idea about your water pump blades tho.
however, today, and the last few days i been still messing around somewhat with my avatars heads going back on. well they are on but then i got the intake on over the weekend and my water pump on today. still painting a few things in the engine bay.
and oh yeah, striped bolt holding on the balancer. which i guess isnt that big a deal but i think my balancer has be moving forward a bit every year, causing the belts to squeel from time to time. i guess sbc didnt use bolts after 68, so not too worried other than i did have to get the balancer i got from summit i think, honed out to fit. i didnt get the memo to put it in the over back in '01.
so i drilled it out to fit a 1/2" fine bolt with a 29/64ths bit. couldnt get my hole hawg in it without taking the radiator out so had to do that too. painting the pulley now. will try to get the carb on tomorrow but dont know. i'm not retired so have to work. and optomotrist tomorrow too so... converting all my nuts and bolts to stainless as well. getting close, just misc pumps and alt. junk. linkage and wiring. distributor. need to buy wires. going to have about a grand into this valve job effort by the time i'm done with the exhaust hooking back up to the new headers.
The Following 2 Users Say Thank You to bullheimer For This Useful Post:
123pugsy (06-21-2018), Too Many Projects (06-21-2018)
  #24642 (permalink)
Old 06-21-2018, 01:01 AM
I got the right kick panel welded in! I was going to have them both, that was the plan. But a family movie night won over that with "Cars 3" and we had fun, what a fun movie.
ID:	431802   Click image for larger version
The Following 5 Users Say Thank You to MARTINSR For This Useful Post:
123pugsy (06-21-2018), cozwurth (06-21-2018), Gearhead Poppa (06-21-2018), John long (06-21-2018), Too Many Projects (06-21-2018)
  #24643 (permalink)
Old 06-21-2018, 02:27 AM
Family nights are approved. Your dedication to five minutes is really paying off though. Looking good.
John
The Following User Says Thank You to John long For This Useful Post:
MARTINSR (06-21-2018)
  #24644 (permalink)
Old 06-21-2018, 05:42 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
BB
CW looking from the front.
As a rule:
CW = standard
CCW = reverse
The "scoop" looks to be the wrong way.
I'm thinking to pull the cover off the new one to take a peak before installation.
  #24645 (permalink)
Old 06-21-2018, 05:44 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Fan pulls of course.
The clutch is working part time only and I think it has to do with this defective pump. As mentioned, it doesn't feel perfect turning it slowly.
The Following User Says Thank You to 123pugsy For This Useful Post:
496CHEVY3100 (06-21-2018)
build thread, projects
Currently Active Users Viewing This Thread: 19 (2 members and 17 guests)
123pugsy, whinny
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Questions 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
