The "What Did You Work On Today" thread - Page 2109 - Hot Rod Forum : Hotrodders Bulletin Board
  #31621 (permalink)
Old 02-01-2020, 07:01 PM
Originally Posted by cozwurth View Post
This past week and a half has been a mixture of good and terrible. The good has been footers dug, forms set, inspections passed, and concrete poured. My garage is scheduled to be erected on Monday. The terrible involves CPR, ambulances, an ICU, and the loss of my dad. He was 76.
Sent from my SM-G900V using Tapatalk
I'm sorry to hear that, prayers going all your way. RIP
The Following User Says Thank You to MARTINSR For This Useful Post:
cozwurth (02-02-2020)
  #31622 (permalink)
Old 02-01-2020, 07:08 PM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
Originally Posted by idrivejunk View Post
Rip, your guy's divining rod must just not be from the right tree, or maybe cut in the wrong moon phase.
This is the kind of impervious individual needed for that kind of job-
I think my guys problem was maybe a wooden leg throwing an unbalance in the whole mess. Hmmmm Maybe he was completely wooden. Now that wouldn't fly in this case..
The Following User Says Thank You to Rip VW For This Useful Post:
idrivejunk (02-01-2020)
  #31623 (permalink)
Old 02-01-2020, 07:15 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
A couple Junes ago, God located my water line for me by pointing it out with a lightning bolt. Not sure if he was pointing at the tree or water line, just glad I was a few yards away and the sewer a few feet. The city's water line busted in the yard months later.
I keep seeing 70+ for Sunday afternoon (please only throw soft things) so I raised hoods today. Checked alt and bat connections on the GTP, took belt loose and spun alternator, tried OBD adapter and tablet app to see voltage but that setup wasn't connecting today and those are kind of like that.
So I got the trusty HP scan tool out. Doesn't have voltage. Really?
Meter (handheld cheapie) shows the alternator and regulator doing straight business. Checked and topped fluids and air, cleaned headlights, did errands with it. All good. I wondered if washing off crap got something wet but no, caught a glimpse of the light on before that. So it WAS poop causing the trouble and once it was rinsed and dried, that fixed it. I was gonna temporarily swap alternators with the GT but no need, it seems. Thats a good cue to swap the younger alt on though, off the 02 engine.
  #31624 (permalink)
Old 02-01-2020, 07:24 PM
idrivejunk's Avatar
Grand Prix User
Wooden fly? What izzat, some kinda fancy special fishin lure in yer neck o the woods?
Let poor old Kaw-Liga be, now.
  #31625 (permalink)
Old 02-01-2020, 07:48 PM
Rip VW's Avatar
IDJ,
What you describe with the alt only blinking a light once in a while I will give you a thought.
I have seen that happen many times with Alternators. It is a sign from the electron Gods that the brushes on the slip rings are just about done. when the brushes are worn past replacement limits they also loose spring tension on the slip ring because they are so much shorter now there isn't a lot of tension left in the spring. The slip rings will likely have crud buildup and probably pit marks from sparking built up on the surface. Just grab some 800 to 1000 grit and wrap the slip rings with the sand paper and rotate the armature.
Hey the good thing is this is a really easy fix just get a brush replacement kit at yer local jobber. The replacement is real easy to do and while your at it pick up a bearing kit and your be flying in voltage and Mr Electron will be happy with you.
Oh don't sweat putting new brushes, There is usually a hole to put a wire in to hold back the brushes while you assemble it then pull the wire and your ready to make some volts and amps.
The Following 4 Users Say Thank You to Rip VW For This Useful Post:
123pugsy (02-02-2020), idrivejunk (02-01-2020), John long (02-02-2020), Too Many Projects (02-07-2020)
  #31626 (permalink)
Old 02-01-2020, 08:07 PM
1971BB427's Avatar
Picked up this stock '39 license plate light for my trunk lid!
And yesterday I got out the markers and my cutoff disc and chopped up my fiberglass frontend for the'39. I'm eliminating the side panels, and making the hood part removable so it will still tilt with grille and fenders, but I can run with or without the hood.
This is just rugh cut slightly large, and I'll block the edges down to the final line by hand for a clean edge.
The Following 5 Users Say Thank You to 1971BB427 For This Useful Post:
123pugsy (02-02-2020), idrivejunk (02-01-2020), John long (02-02-2020), Rip VW (02-01-2020), Too Many Projects (02-07-2020)
  #31627 (permalink)
Old 02-01-2020, 08:53 PM
idrivejunk's Avatar
Grand Prix User
IDJ,
Yessir, theres that. And I have rodeoe-ed with having alternators apart afore. Not the 1999 style though. It has been real gradual but over time, load changes affect RPM more and more. When I spun it by hand awhile ago, it felt like yep what you describe. I wanted to eyeball things because of recent work where I just sat the alternator aside connected.
Situation is, up at work is where I keep the spare engine and theres been a perfectly good 135K miled original unit been sitting on top doing nothing five years while I wore the 278K miled one out. The only way to get the transportation value out of junk is to drive it out. I need it to go a hundred more miles or so without a gone brush chunking and stopping the works. Might not be a bad idea to borrow the good one off the 180K backup car and have it with until I swap.
But I'm a long way from needing to walk into a parts store. Did that last weekend for a $20 pulley. Thats probably $4.99 shipped, off Amazon or whatever. I still got half my gift card left.
  #31628 (permalink)
Old 02-02-2020, 04:35 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
70? Man, did my old man go to the wrong country.
Have a nice rip-snort.
The Following User Says Thank You to 123pugsy For This Useful Post:
idrivejunk (02-02-2020)
  #31629 (permalink)
Old 02-02-2020, 04:50 AM
123pugsy's Avatar
Wiki Edits: 29
I had a fella come by for some hands on metal shaping training. Got me a free lunch....
I have no ewheel in the garage. He did quite well using only hand tools.
ID:	451547   Click image for larger version
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
idrivejunk (02-02-2020), Too Many Projects (02-07-2020)
  #31630 (permalink)
Old 02-02-2020, 06:53 AM
Molon Labe's Avatar
Last journal entry: Floors
1971BB427,
I love the front end on that '39. It's going to be a beautiful car.
The Following User Says Thank You to Molon Labe For This Useful Post:
1971BB427 (02-02-2020)
  #31631 (permalink)
Old 02-02-2020, 07:02 AM
It looks like you have done a good job making that grill fit too!
John
The Following User Says Thank You to John long For This Useful Post:
  #31632 (permalink)
Old 02-02-2020, 07:05 AM
That is amazing for a beginner using only hand tools. The instructor should be very proud of himself.
The Following 2 Users Say Thank You to John long For This Useful Post:
123pugsy (02-02-2020), idrivejunk (02-02-2020)
  #31633 (permalink)
Old 02-02-2020, 07:53 AM
1971BB427's Avatar
Originally Posted by Molon Labe View Post
1971BB427,
I think the '39 front end is one of the best designs Chevy came up with in the 1930's. When I owned my '40 Chev back in the 1960's I always wished it had a '39 grille! Never could find the front clip for a '39 to swap on it.
  #31634 (permalink)
Old 02-02-2020, 08:18 AM
idrivejunk's Avatar
Grand Prix User
Forget how nice the part looks, I am still ogling just the buck in awe.
The Following User Says Thank You to idrivejunk For This Useful Post:
  #31635 (permalink)
Old 02-02-2020, 08:49 AM
idrivejunk's Avatar
Grand Prix User
Looks like you have that front end going in the right direction. Nice! I have never messed with tilt front ends but do have a thought which might be relevant. On a 41 Ford pickup we did which was all gennie steel fenders, I made the front fenders and inner fenders one piece. Mostly just welding where they originally bolted.
The fenders were so fragile before that I did not think they would live past handling for the paint process. Doing something like that might apply to your rod, too. Might be that you could glass a metal flange onto the backside of the fender to bolt an inner to. 40s fenders are just mighty big. Have fun and stay out of the itching powder cloud (cutting fiberglass).
build thread, projects
« Trivia thread | - »
Currently Active Users Viewing This Thread: 11 (1 members and 10 guests)
Rip VW
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
Increase thread title "preview" time cboy Hotrodders Site Problems 16 07-03-2008 08:45 PM
