The "What Did You Work On Today" thread - Page 2114 - Hot Rod Forum : Hotrodders Bulletin Board
  #31696 (permalink)
Old 02-09-2020, 03:24 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
OK, technical stuff then. I have 14.09V at back of alt, 13.81 at battery terminals, and 13.74 from jumpstart peg at fusebox to strut bolt. The OBD2 port under the dash has 13.70. I did not pull the fuel pump cover today to look at wires but did touch the GT a little. The above numbers look good to go though, eh?
  #31697 (permalink)
Old 02-09-2020, 03:31 PM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I like those numbers. Obviously, the engine is running during this check.
  #31698 (permalink)
Old 02-09-2020, 04:48 PM
idrivejunk's Avatar
Grand Prix User
Certainly, yes I forgot to put the word running in there. Guy who helped me has a Chevy, see if his cold start gets the girl too.
The Following User Says Thank You to idrivejunk For This Useful Post:
123pugsy (02-09-2020)
  #31699 (permalink)
Old 02-09-2020, 05:20 PM
123pugsy's Avatar
Wiki Edits: 29
Made up a couple of blisters, performed a double mastectomy and got one ready to weld.
Sprayed some paint on one for a looksee. Not perfect but I'm sure I can smooth them out with high build and some good sanding technique.
ID:	451743   Click image for larger version
ID:	451745   Click image for larger version
ID:	451747   Click image for larger version
ID:	451749   Click image for larger version
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (02-10-2020), idrivejunk (02-10-2020)
  #31700 (permalink)
Old 02-09-2020, 07:27 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
Do you ever have thoughts of putting a five speed in one? I say that in a hovering vulture context, having been stuck with just two pedals for two decades now and lusting for cast-aside four speeds. But a five speed... might require bigger wheels to fit tires that would take the overdrive exploration. Road trippin a stick car without beating it to death might be fun.
I would love a 5 or 6 speed in ALL my cars, but they get too expensive very quickly. I bought an M20 for the Camaro a couple weeks ago. The M21 doesn't work well with the 3.31 gears. I spent a LOT of coin rebuilding the M20 last summer and now don't know what I will do with it. Well, that's not entirely true. I would like to put it in the '54 instead of the TH350. that has a '57 rear axle now with a 3.73 posi...
The Following 2 Users Say Thank You to Too Many Projects For This Useful Post:
123pugsy (02-10-2020), idrivejunk (02-10-2020)
  #31701 (permalink)
Old 02-10-2020, 06:19 AM
idrivejunk's Avatar
Grand Prix User
Every chance I have had to ask an aftermarket six speed owner, they all say sixth isn't legally usable... not a speed limit high enough in this country to cruise in sixth, or engine won't pull that much gear along at low RPM. But a five speed with the right spread,.
Then theres the other end of the spectrum which is what you mean by 3.31s / M21. First gear not being right sucks worse. So not just anything will do. The fact we like stout but mild big V8s limits choices. Personally, I haven't used up the TH400 that came in mine and am on the second engine. And the barely used second TH400 is still waiting on the garage floor. You know me, I gotta use stuff all the way up before I chunk it so I am probably destined to be a slushbox man all my days.
  #31702 (permalink)
Old 02-10-2020, 07:08 AM
I have had double and tipple overdrive in a couple of my rides. You end up using gearing in the 5 or 6's and some fun driveshaft speeds.
My current build has a 4 speed with a 3 speed aux for 12 speeds with a 2 speed transfer case. That is being done for overdrive and the ability to run 4.11 gearing.
I have went the other way and mated 2 sm465's together
to get 16 speeds in a 81 suburban. Basically I could pull down a house with a tbi 2.5 4 cylinder and then cruise down the road with 3.08 gearing. That old boat got mileage in the 30's and over 23 in town.
Electric is becoming cheaper and they don't like to run stupid rpm. Running double or triple overdrive with an electric allowing that engine to drop it's rpm beyond what any gas engine is capable of is coming.
I prefer to just run direct to wheel motors and eliminate the transmission, axle shafts, driveshafts, and differential.
Having 4 motors that could provide superior traction while eliminating weight and increasing efficiency.
My idea of a perfect hotrod is 4 electric motors with a single cylinder gas engine to charge the pack with a final height around 35".
But anyway.
I found some junk wiring on the 94 k1500 today and fixed it before ordering some led taillights to eliminate the common circuit board issue.
Led lights with integrated slow flash.
https://www.ebay.com/i/273562215017?...SABEgJC8fD_BwE
  #31703 (permalink)
Old 02-10-2020, 12:13 PM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
My personal Black cloud is BACK!!!
I survived the flooding around here got all forms ready to pour and got the ground somewhat dry! We were set to pour today as it is a beautiful day the weather is supposed to be good today and tomorrow and then back to rain the rest of the week.
My contractor shows up this morning says he has bad news!! His concrete pump truck is broken down and won't be repaired till late Wednesday and the earliest he can pour is Thursday afternoon!!! Soooo here we go all dressed and no where to go... Today was supposed to be truss delivery day but they had to push that till next week! ARRRRGGGGHGHGHGH!!!!! I am so sick of this whole process. Instead of enjoying the build, this build has been like a big dead albatross hanging around my neck. This delay is going to add another month of $500.00 storage fees to my already flat bank account!!
The biggest takeaway from this whole thing is I hope to NEVER EVER have to deal with State, County, and city governments and contractors ever again. I am so sick of this whole process! I think it is designed to take your money and give you heartburn for life.
I think I am going to grab my 12 year old scotch and go hide in the electronics lab for the day!!! Have fun everyone....
The Following User Says Thank You to Rip VW For This Useful Post:
  #31704 (permalink)
Old 02-10-2020, 03:36 PM
That sucks, RIP. Uncover the forms and let them dry for the 2 days and then have the contractor cover them again for the rain.
123pugsy (02-10-2020), Rip VW (02-10-2020)
  #31705 (permalink)
Old 02-10-2020, 04:16 PM
Hang in there RIP. You are trying to build a building in the rainiest season of the northwest. It will happen. It is a wonder anything gets done in northwest Washington in February, even without the asinine bureaucracy.
John
The Following User Says Thank You to John long For This Useful Post:
  #31706 (permalink)
Old 02-10-2020, 05:02 PM
123pugsy's Avatar
Wiki Edits: 29
Got the new blisters tacked in place.
The Following 3 Users Say Thank You to 123pugsy For This Useful Post:
496CHEVY3100 (02-11-2020), Gearhead Poppa (02-11-2020), idrivejunk (02-10-2020)
  #31707 (permalink)
Old 02-10-2020, 06:25 PM
cozwurth's Avatar
Last journal entry: Vinyl top carnage...
The county came out and inspected the shop today. Approval acquired. Next is to pull a permit to do the electrical work. I also need to get the roof insulated so I can get the lift set up an off the trailer. Can't roll the scaffolding around if the lift is there. Anyone have an idea what type of fluid an ALM lift requires? I cant find anywhere near as much info on this one as i could find on the rotary 2-post in dads garage. Fluid that was evacuated before I took it apart was clear, and the shop owner I bought it from didn't know.
Sent from my SM-G900V using Tapatalk
  #31708 (permalink)
Old 02-10-2020, 06:52 PM
I would think any quality aw 32 hydraulic oil would be fine. I used that in my Pete pump with end dumps and side dumps for 17 years. Pretty cheap at farm type stores, like Tractor Supply, versus auto parts. You could probably use a trans-hydraulic oil too, but that is usually more expensive.
The Following User Says Thank You to Too Many Projects For This Useful Post:
cozwurth (02-10-2020)
  #31709 (permalink)
Old 02-10-2020, 06:53 PM
IRON MAIDEN...
123pugsy (02-11-2020), idrivejunk (02-10-2020)
  #31710 (permalink)
Old 02-10-2020, 07:13 PM
I have the patterns transferred to the vinyl for my second go at the RH back rest.
I screwed up the first try big time but since the LH side went well, I expect this one will to..........this time
Fortunately, Barb has not been in the kitchen tonight.
John
The Following 3 Users Say Thank You to John long For This Useful Post:
123pugsy (02-11-2020), Gearhead Poppa (02-11-2020), idrivejunk (02-10-2020)
build thread, projects
« Trivia thread | - »
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 04:26 AM
Increase thread title "preview" time cboy Hotrodders Site Problems 16 07-03-2008 08:45 PM
