The "What Did You Work On Today" thread - Page 523 - Hot Rod Forum : Hotrodders Bulletin Board
  #7831 (permalink)
Old 03-23-2014, 03:36 PM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
I just noticed the shifter .just like a Metropolitian I once had .
  #7832 (permalink)
Old 03-23-2014, 03:39 PM
Yep, it's not your usual "column shift" it's more of a "Dash shift".
The Following User Says Thank You to MARTINSR For This Useful Post:
496CHEVY3100 (03-23-2014)
  #7833 (permalink)
Old 03-23-2014, 04:31 PM
CraigK's Avatar
Last journal entry: For a change of pace
I have been kicking these doors around all day. Finally have an acceptable fit. Until I put the weatherstripping on, we will see. I am sure more tweaking is in order soon. I have one spot, the door almost touches, just out of the blue. I am thinking FBH and a dolly should do it.
Oh, I lost a big shim down the inner cowls. I dropped it when I was tweaking a hinge. Good new is it is the side with an opening. Bad news is it is stuck. One way or another that thing has to come out.
ID:	130274   Click image for larger version
ID:	130282   Click image for larger version
  #7834 (permalink)
Old 03-23-2014, 04:52 PM
Hope you didn't do as I did ,I installed the weatherstrip backwards (,the way it fits best ) but it was wrong doors liked about 3/8 closing after about 4 hrs of trying to ajust them,so I turned it ,the weatherstrip around doors close flush now started to change hinges glad I didn't ,
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
CraigK (03-23-2014)
  #7835 (permalink)
Old 03-23-2014, 06:04 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
David, that overhead storage looks really nice !!!
Craig, you are a bit "persistent", eh ?? I like that you keep going right back at it until you whip it's butt...
I posted some pics of a GTO I am repairing a couple weeks back. I have been plugging away since then and got it done today.
Shaping the trunk pan extensions.
The owner was here last Saturday and we fit the tail panel and I tacked it in, but I wasn't happy with how the left side looked. Sunday I went back out and looked closer and it appeared to have moved during the tacking process. I cut 12 tacks out and moved it 3/16ths further into the quarter corner.
All done welding and the extension seam sealed.
I had to form a patch to repair a hole in the quarter panel that the tail panel attaches too. More of the seam sealer to blend the repair too.
Wire wheeled the underside for sealer too.
My part is done. He will do all the final cleanup and finishing...
The Following 4 Users Say Thank You to Too Many Projects For This Useful Post:
123pugsy (03-23-2014), CraigK (03-23-2014), John long (03-23-2014), tech69 (03-23-2014)
  #7836 (permalink)
Old 03-23-2014, 06:15 PM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Got the new firewall and braces bent up this morning. I welded up the braces and temporarily bolted everything in place.
Got it back on the rotisserie to start laying out the new floor.
The Following User Says Thank You to 123pugsy For This Useful Post:
CraigK (03-23-2014)
  #7837 (permalink)
Old 03-23-2014, 06:50 PM
CraigK's Avatar
Thanks, I will for sure keep my eyes on that weather strip!
  #7838 (permalink)
Old 03-23-2014, 06:59 PM
Mine has a groove in the rugger it turns to the outside then the metal strip on the bottom of the door bolts to it,,i didn't look right but that is what the assembly manual shows and it works
  #7839 (permalink)
Old 03-23-2014, 07:26 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition
Wiki Edits: 3
Originally Posted by Too Many Projects View Post
Between using our arms/hands extensively, I have arthritis growing in my joints. I've had ulnar transposition and carpel tunnel surgeries on both wings in the last few years. The carpel was so bad, I couldn't sleep anymore. MUCH better now. Get a DR.s opinion.
I had both knees replaced when I was 50. Since then I have had both shoulders and one hip joint replaced, Carpal tunnel surgery in both wrists, my left wrist fused and many , many injections in my back the past year trying to aleviate some of the back pain. At times my right hand hurts so bad that I wake uo sobbing with pain. Now my right wrist has gotten so stiff that I have to sit on my lower arm to wipe my butt. Scheduled to see a hand surgeon on April 1st.
Worked hard as a heavy equipment mechanic for twenty years, up until the last ten years, when I was a supervisor.
Maybe it wasn't such a good idea to carry around small block chevy blocks and hit concrete walls in frustration when I was younger. Keeping in mind that I was only about 155 lbs at the time.
Once when I was hammered, I hit a utility pole with a mercury vapor light with my fist so hard that the light went out and had to reset. Was a tough 155 lb 19 year old.
BTW was only in one fight in my life, when I was 16. Very quiet guy.
  #7840 (permalink)
Old 03-23-2014, 07:34 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Yeah I am wondering about my left arm because it's in the muscles on the top of my arm. Just holding my coffee cup is getting hard. The right arm is totally different in that it is IN the joint.
Let us know what you find out about your arm. Both of my forearms knot up sometimes like I have just got done lifting weights.
  #7841 (permalink)
Old 03-23-2014, 10:12 PM
BOBCRMAN@aol.com's Avatar
Sometimes this can be a side effect of medicine. One of my heart meds was doing similar. Wake up in the night to screaming painful muscle cramps.. Had to change it.
I was having joint problems and had gotten to the point that I could not hold a hammer. Changed doctors and was then treated for a form of arthritis.. Not only cleared up the shoulder/arm/hand problem but also cured back problems that I'd had for over twenty years.. Methotrexate.. Good luck..
  #7842 (permalink)
Old 03-23-2014, 10:18 PM
I was talking with a senior agent for Workers Compensation here. About guys in their 50's getting retrained because they are messed up from working in the trade. She told me flat out, "We retrain and get you guys, get you desk jobs, good jobs, but the problem is, if you guys have done this for 30 plus years, and liked your job, after a few months you old guys just suck it up and go back to your trade. You guys just figure out how to work around the pain, suck it up and get a helper"
During that conversation ( I was taking classes to retrain as a safety officer ) I realized something. I am going to die with a wrench in my hand. Be it a furnace or a truck, I will die with a wrench in my hand. I have the tool picked out I am to buried with. I stopped on the way home and picked up new splints for my wrists and elbow and then I bought a small cordless drill that fits in my pocket.
I never use the cordless pocket drill. I find tylonal more useful in my pocket.I also decided to let the safety officer certification laps this year.
If it makes you feel any better Art Arfons was buried in his fire suit, a wrench in one hand his assembly manual for a jet engine in the other hand and a jar of salt from Bonneville at his feet. You'll be in good company.
BB
  #7843 (permalink)
Old 03-24-2014, 05:18 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
Form this to this. A good night all and all. One done one to go. Next one easy, just file out the hinge holes 1/4 inch.
Looks better,
  #7844 (permalink)
Old 03-24-2014, 02:26 PM
put up or shut up
what a horrible day, and horrible boss. So the new painter started and it's back to the body shop and we're already running out of work. I told the boss that GOOD workers don't want to work for shops where there's no consistent work flow. I told him if I get sent home I'm gonna be pissed and that if he keeps running his shop this way he's gonna end up with a bunch of rejects that will accept cause they can't work for anyone else. This man doesn't value quality otherwise he wouldn't be putting me thru this. I go so does his quality with efficiency. The way it's looking now, I feel like taking my tank and going next door and ask for a job. This guy can't seem to be set on any decision he makes cause he doesn't know what he's doing and so I have to gut it thru all his lame decisions while trying to pay for a babysitter.
  #7845 (permalink)
Old 03-24-2014, 04:02 PM
That sucks alright.
build thread, projects
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Hahaha Remember that "Hemi in a Camaro" thread... Crazy Mopar Guy Hotrodding Basics 16 11-07-2015 05:26 AM
Another engine "tick" diagnosis thread....(long) ForceFed86 Engine 2 04-09-2011 04:54 PM
Increase thread title "preview" time cboy Hotrodders Site Suggestions and Help 16 07-03-2008 09:45 PM
MuscleCarKid_1991 "Senior Project" thread: Dumped Jon Engine 2 03-22-2008 09:01 PM
"Trial fitting parts" thread vs. paint thickness rcurrier44 Body - Exterior 3 01-26-2005 06:24 PM
