  #15229 (permalink)
Old 01-27-2016, 08:24 PM
69612 69612 is offline
Guest
Location: in the land of Trolls at least till the san andreas releases the big one
silicone and brake rotor 3... wayne. 0... round 4 coming up tomorrow..
i did find the rotors are available.. only 1250.00 each plus shipping from italy.
they look very much like the front rotors from a 80 BMW 733i... that is what the hydraulic brake calipers are .. front and rear. uses the front ones all the way around.
picture 3 is the best one.. it has a large hex 1/2-13 nut welded to the side of a 1/2-13 coupling nut... that fits thru the hole in the side of the rotor hat really well... the thickness of the grade 8 bolts is actually some springs i picked up so the puller legs did not slide around while i was trying to get the puller tight.
i have an OTC wheel hub puller.. with 5 legs... i think i will dig that out and try that. i have enough extra coupling nuts and an extra pair of large hex nuts to do it.. pulling on all 4 holes..
ID:	270945   Click image for larger version
ID:	270953   Click image for larger version
