Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What to do for this rust repair?
Old 06-01-2010, 10:48 AM
chevymike's Avatar
chevymike chevymike is offline
Thanks for the detailed reply.
Actually the inside of the door is in perfect shape, outside of the corners (which you can't see from the inside. I had checked this out before buying this truck as I knew rust was a problem in these areas. Cutting off and redoing the outer skin in the corner areas would give me access to the inner part that is rusted.
The biggest reason I would like to not have to do the whole lower panel is most of the patch panels are very lightweight compared to original metal. I have done a few patch panels in the past and the quality sucks and they seem to warp much easier than the orignal steel.
I'll see if I can track down some Rust Cure. I'll at least cut out the outer corner skin and see what I am working with.
Thanks again.
