what guage sheet metal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2011, 06:39 PM
A Todo Madre o Un Desmadre
Last journal entry: 700r4 rebuild
I have a 1963 c10 short bed and I want to do some patch panels on the doors and was wondering what gauge sheet metal I should use .... any suggestions any one?
Old 03-15-2011, 07:49 PM
Rag top bird's Avatar
Hot rods are still the king
I think That should be 20 ga that is what I would use
Old 03-15-2011, 07:52 PM
Thanks for the advice can I get away with using 22 gauge that's all I been able to find around the town I live at
Old 03-15-2011, 08:22 PM
you can use 22 ga if I were you I would start my weld on the heaver gage metal so you dont burn a hole in the panel
Old 03-16-2011, 11:37 AM
Around here I can only find 16 and 22 gauge. If you can, try to find the 16. It would make a better repair as it's stronger. I've used the 22, but wouldn't trust it for anything more than a small patch as it will be weaker and bend easily.
Old 03-16-2011, 01:20 PM
Underground's Avatar
Last journal entry: 54
I bet the metal is closer to 18 gauge. You need to keep the patch the same as the rest of the metal because the lighter of the 2 will warp more and cause more bodywork. If you have to, cut the patch out of an old body panel. You can buy a sheetmetal gauge tool at most hardware stores. Then you will know for sure.
What guage metal to build trans hump? 1badLemans General Rodding Tech 8 01-08-2011 09:31 PM
sheet metal camarossrs56 Introduce Yourself 4 08-22-2007 07:48 AM
sheet metal ? jackodom Body - Exterior 2 04-28-2007 05:57 PM
Where to buy Sheet metal cab Body - Exterior 12 07-25-2006 07:38 PM
sheet metal help?? gmthomas44 Hotrodders' Lounge 2 09-17-2002 09:53 AM
