What are my options here for this steering column - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-23-2019, 05:13 PM
ericnova72's Avatar
More for Less Racer
Steering stops are internal in the box, so it isn't anything to do with your new shaft unless there is a spline slipping(wrong size joint) at the box.
The steering column and shaft does nothing to limit the travel.
Is this a power box?? Checked it with engine running??
  #32 (permalink)
Old 06-23-2019, 05:32 PM
39 master's Avatar
If you have 3 U joints you need a support bearing on one of the DD shafts...you do have one installed, correct? Pictures?
  #33 (permalink)
Old 06-23-2019, 07:18 PM
47 Ford Coupe Delux's Avatar
I did install a support bearing which I made out of a piece of aluminum sheet. Flexes a little though so I'll have to get a steel one eventually.
  #34 (permalink)
Old 06-23-2019, 07:22 PM
After I posted this remembered that the set screws on the u joints are too long and sticking out and one is probably preventing the shaft from spinning all the way around. I'll have to take a look tomorrow but I'm almost certain that's got to be the issue.
  #35 (permalink)
Old 06-23-2019, 07:27 PM
CaptMike's Avatar
Capt Mike
Or you did not CLOCK your Steering Column to the Middle.
  #36 (permalink)
Old 06-23-2019, 07:42 PM
Once the steering shaft is disconnected from the column the steering column shaft can spin infinitely (it has no left or right stop) so I don't believe that makes a difference.
  #37 (permalink)
Old 06-23-2019, 11:35 PM
39 master's Avatar
If you made a support bearing from aluminum and it flexes AND the wheels won't turn left and right you need to stop right there and call in a second set of eyes. Recommend you get in touch with a local car club and ask for someone in the club that does some building and have him look at what you have.
  #38 (permalink)
Old 06-25-2019, 01:19 AM
All set, got everything working properly. Issue was a protruding set screw on the u joint making contact with the cross-member therefore not allowing the steering shaft to rotate completely. Special thanks to Ericnova72 for all the help with this issue.
  #39 (permalink)
Old 07-03-2019, 04:00 PM
arnoldsel's Avatar
Neighbor has a 46, Could take pic
My neighbor has a 46. Looks like yours. He has a 383 Chevy in it. Almost positive it has Block huggers headers. However I think it has a Mustang II suspension. What is your suspension? Would probable make a difference. I could take a pic never the less of his...
Ford Steering Column Help wanted. Mr.Fixxit Suspension - Brakes - Steering 1 06-10-2012 10:10 AM
steering column chevy73 Suspension - Brakes - Steering 0 03-06-2012 10:58 PM
Steering column for my '29 Mike Britton Suspension - Brakes - Steering 3 12-31-2006 01:09 AM
Steering column oldgolpher General Rodding Tech 3 09-23-2006 02:27 PM
shortening the steering column smoran Interior 3 05-02-2002 07:38 PM
