Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What Is The 'Right Way' To Install Freeze Plugs ?
Old 09-27-2006, 03:31 PM
Bonehead4x4 Bonehead4x4 is offline
Brass is used in boats, for the corrosion resistance, but works well in cars too. Either way, coat the outer surface with the brush-on Permatex, then drive it in straight with the largest socket that will fit. Install it so the outer edge is flush with the block.
