Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What Is The 'Right Way' To Install Freeze Plugs ?
Old 09-28-2006, 09:36 PM
SCHOONER's Avatar
SCHOONER SCHOONER is offline
Thanks For You Expert Imput Guys
HI GUYS
Here's what I finally did.
I bought the BRASS FREEZE PLUS and used this sealant called;
" THE RIGHT STUFF "
Bought it at: AUTOZONE, its expensive $13.00 bucks! But its worth it. I don't want ANY LEAKS
I cleaned the freeze plug holes in the engine block with brake cleaner and coated the hole with just the right amount with my finger.
Then I did the same just around the edge of the BRASS PLUG. With a large enough socket I tap-taped the brass plug into place. It stayed even all the way around into the engine block.
THANKS FOR ALL YOU IMPUTE GUYS.
GOD BLESS
Schooner
