What should I do/check when replacing valve covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2016, 04:31 PM
Rusticcreationsme's Avatar
1987 Dodge D150
Installing my new cast aluminum mopar performance valve covers tomorrow and was wondering what I should check or inspect when inhave the valve covers off?
87 dodge 318.
Old 07-04-2016, 04:39 PM
OldTech's Avatar
Look at the valve seals to make sure they aren't cracking, look at the valve train to see if there are any irregularities, see if any sludge is building up (water in the oil and or excessive heat), replace the PCV valve, and check the oil return holes.
Basically it is all visual inspections and won't take long.
Old 07-04-2016, 04:42 PM
Last journal entry: Still running strong
Only thing I know of is to lay them on a some glass to make sure there flat.I don't know about Fel-pro Morpar gaskets but the blue ones for Chevy you don't have to glue them.
Old 07-04-2016, 05:18 PM
1987 Dodge D150
Ok thanks guys, I appreciate it, I know just enough to get myself in trouble so i always like to ask questions before tackling something.
Old 07-04-2016, 06:33 PM
ntfday's Avatar
Everyone has a different method for gasket application and here's mine. I will douse a rag with brake parts cleaner, with proper protection, and thoroughly clean the mating surfaces on the heads. Brake parts cleaner leaves no residue and will get all of the oil out of the crevices. After checking the fit of the gaskets on the valve covers I apply a light coat of Permatex#2, set the gasket in place, put bolts in the holes on the valve cover and hold everything in place with plastic clothes pins. After about a half hour remove the clothes pins and the bolts and slap the valve covers on. They won't leak and the gasket will stay in place if you have to remove the valve cover later.
Old 07-05-2016, 02:53 PM
T-bucket23's Avatar
Last wiki edit: Engine basic condition - how to check
Wiki Edits: 26
87 dodge 318.
A good look around for heavy sludge is always a good thing while you have the covers off.
Other than that if you are not having any issues leave it alone. More people get in trouble fixing things that are not broken. You can find many threads here that start with "my car was running fine but I wanted to adjust" and the next sentence explaine that it no longer runs correctly.
the old adage, if it aint broke, don't fix it applies
Chet
The Following User Says Thank You to T-bucket23 For This Useful Post:
OldTech (07-05-2016)
Old 07-05-2016, 06:24 PM
I've always thought it was important to not over-tighten the bolts and distort the cover, thus causing a leak.
Replacing bench seat covers in a 70 Ragtop alittle1 Interior 11 02-28-2013 07:08 AM
how to check valve seal and valve guides daveid Engine 3 11-06-2007 06:02 PM
Replacing valve seals 35olds Engine 3 02-11-2006 01:05 PM
EGR Valve in the way of new valve covers Jag Daddy Engine 9 05-16-2004 11:05 PM
replacing valve springs stfinney Engine 8 09-06-2003 10:46 PM
