What to spray on the inside of fenders and wheel wells? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2017, 02:03 PM
LenB's Avatar
So I'm finally getting close to painting my 68 Mustang. I stripped the entire car to bare metal all the way around. I then sprayed everything with Epoxy Primer. The engine bay I plan to BC/CC in a satin black. Should I do the same to the back side of the fenders, floor pans, and wheel wells or just leave them in black epoxy primer, or is it best to spray a rubberized undercoating on these areas. I plan to just use it as a summer weekend show car / cruiser. Whats the right way / industry standard for these areas and what products are best for these areas?
Old 03-16-2017, 07:51 AM
delawarebill's Avatar
spray'n
those places u mentioned are more/less out of the way and most likely black.. i like the bed liner in spray cans. u can get it at local auto parts.
Old 03-16-2017, 09:25 AM
Irelands child's Avatar
Last wiki edit: Ford engine specifications
X2 for bed liner spray cans. Just make sure you can control the overspray as it is next to impossible to clean off
Irelands child
Old 03-16-2017, 10:24 AM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
Myself, I stay away from the bedliner/undercoating stuff... If you ever want or need to do anything under the car the rubber stuff just makes a mess. Shoot it with your BC/CC satin black and call it good. Top coating the primer is a good thing to get it sealed up. Epoxy is tuff stuff but it should be sealed up.
Mark
Old 03-30-2017, 04:00 PM
bsa_bob2's Avatar
Originally Posted by hcompton View Post
Im not sure rubber bed liner is going to be great for areas near the headers. Might burn it or melt or even just make it stink to high heaven.
They make some chassis black that is pretty tuff. Bed liner is fine in areas that dont get such high temps. I think some of the better undercoat and bed liners are heat and fire proof over 600 degrees and that should be fine for near the headers.
You can also look at the bed liner systems they often rent equipment and tooling needed to work with the product. They can also let you know if its going to stick and work in the under hood temps. I think rhino liner and the like are pretty tuff once they set up. Not sure of the rattle can stuff.
Hope this helps.
spray can undercoat --rubberized. I have 2 kars i put it on--- not show quality but i'm gonna drive this 55 It stays just fine. mo
Old 03-30-2017, 08:52 PM
put up or shut up
get catalyzed, it's much more durable. The rattle can stuff is comparable to a rattle can primer. The two part stuff is amazingly durable. The Raptor stuff is good. SEM? It's been a while since I used it but it's great stuff. I sprayed the wheel wells of my mustang with it and it looked awesome.
Old 03-31-2017, 09:32 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I use the bed liner but just on the wheel wells where rocks and dirt can get thrown up, no where else.
Sam
Fabricating Wheel Wells reddogracing Body - Exterior 6 04-23-2015 04:30 PM
Cleaning up wheel wells briansansone Hotrodding Basics 8 02-13-2012 02:36 PM
removing wheel wells! cudablack2004 General Rodding Tech 4 06-23-2011 09:40 AM
What can I spray inside street rod fenders to keep paint from cracking on other side hemi43 Body - Exterior 8 06-23-2006 08:20 AM
Help with wheel wells? workingclass Body - Exterior 29 02-14-2006 10:20 AM
