What are these called? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2019, 04:43 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
The car is a 50 Chevrolet 2 door hard top. These clips are in the door and hold "nails" to mount the door panel. I'm missing a few and have no idea what to search for. Or, is there a better way to mount the door panels using the existing holes if the clips were all removed? The door panel base will be a stock replacement backing.
Thanks in advance!
Old 07-27-2019, 06:22 PM
BillPac's Avatar
Interior clips
Those look like a type of metal retainer clip. Take one out, and go to a body shop, or auto supply and ask. Believe it or not, Auto Zone stocks pieces such as that.
The Following User Says Thank You to BillPac For This Useful Post:
S10Fan (07-27-2019)
Old 07-27-2019, 07:26 PM
S10Fan's Avatar
Garage Filler
Thanks, I'll check that out.
Old 07-27-2019, 07:57 PM
Generally nobody replaces the door panels with nails. It is much easier to pick up some standard door panel clips, drill holes for them in the door, and go that route.
you should be able to find all sorts of examples on a search of the net. Here is one of many.
https://www.trifive.com/forums/showthread.php?t=76948
John
The Following 2 Users Say Thank You to John long For This Useful Post:
22george (07-28-2019), AirwolfPJ (07-30-2019)
Old 07-27-2019, 08:43 PM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Might find something to work here;
https://www.perfectfit.com/15290/Tri...Fasteners.html
https://www.thefastenerwarehouse.com/home.html
https://www.fastener-warehouse.com/Default.asp
happy hunting
Pep
Old 08-06-2019, 04:04 AM
S10Fan's Avatar
Garage Filler
I took the advice you guys gave and went to work. I now understand why the factory used nails every couple inches, lots of curves in the door. Anyway, I rounded up some panel clips and carefully marked where I thought they should be. I'll be adding a few more, I needed a general idea where to get started. The bottom of the panel is held in place with a factory style metal strip that slips over a matching piece on the door. A hand punch I bought from Eastwood years ago was perfect for the clip holes.
PLEASE offer any comments on anything you see that I need to improve on. The panels will be getting closed cell foam (I think that's what it's called) and vinyl with another vinyl covered panel that will run across the speaker area. Stainless steel mesh will be the speaker grill.
ID:	445843   Click image for larger version
ID:	445845   Click image for larger version
Old 08-06-2019, 07:06 AM
It looks like you have a good start. Good luck with them.
John
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
