"Whatdidja make?" - Page 9 - Hot Rod Forum : Hotrodders Bulletin Board
  #121 (permalink)
Old 05-08-2008, 11:05 AM
http://www.1969supersport.com/dog1.html
http://www.1969supersport.com/tls.html
This is a jig for a 1969 supersport body
http://www.1969supersport.com/jig01.html
http://www.1969supersport.com/roto.html
Rob
  #122 (permalink)
Old 05-09-2008, 11:23 AM
aminga's Avatar
Last journal entry: Cleaning and Powder coat
I made a cat carrier
  #123 (permalink)
Old 05-09-2008, 02:07 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I can't resist. That must be the "Catillac" of Cat carriers.........
In a while, Chet.
  #124 (permalink)
Old 05-12-2008, 10:56 AM
Don't have pictures of it, but I've got a cleaning/assembly "table" that I can throw together in a couple minutes: Pair of folding sawhorses, 2' x 4' sheet of 3/4" plywood for the top, a metal drip-pan with a hole drilled in one corner, a length of 2x4 to raise one end of the table (to direct junk/dirt/fluid towards the hole), and a bucket on the floor to catch the run-off. Used this to clean, strip and rebuild a th350 no problems. Hmm, might see if it's strong enough for a bare SBC block . . .
Also made my own spring compressor for the th350 - length of 1" square tube, some 3/8-16 all-thread, 1/4" x 1" hot rolled formed into a U-shape and a couple nuts and washers.
Made some stuff to help fill/drain a carb bowl with fuel. Short length of exhaust pipe and formed sheet metal to make a flat-bottomed ladle (with spout). The handle also helps to drain a Holley fuel bowl - stick the end of the handle under a screw and let the fuel drip into the handle and down into the cup part. Second piece is funnel out of a short length of 3/16" brake line and more sheet metal formed into a crude cone. Slides right down the vent tube.
- Mike
  #125 (permalink)
Old 05-13-2008, 07:50 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
here is a quick paint boot that has work amazingly well, I am using a blower from an AC air handler, it is rated at 3 tons. The duct is 12 inches this thing is working like a down draft booth. Yes the filters are at floor level but the blower pulls air across the floor and I am getting NO trash in the paint .. just another way to make a booth, but I think this is the first one I have seen or heard of using an AC blower.
One more comment ........... Iwata paint guns ......... a painter it makes.
I will add this if you are a home builder and find a color that is 400 - 600 a gallon, from where I stand go and plunk down 400 more and buy an Iwata you will NEVER be sorry you did. The gun puts the paint on the parts and not out the vent and down the duct... A very worth while tool....
And no I did not buy 400 -600 a gallon paint
ID:	29908   Click image for larger version
  #126 (permalink)
Old 05-13-2008, 08:05 PM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
hand tools
I got paid $ 50 to remove a one ton rated southworth 4 ft by 4 ft lift table ,, when i built the new shop I welded up an angle iron frame and recessed it so when it is down it is flush with the floor. I cut square holes around the edge and welded in the mini receirver trailer hitch tubing some square and others at various angles. I welded square tubing to 5 x 6 flat plates an bolted on a vice, pipe vice, hossfiels bender, small brake, bead roller. planishing hammer etc ,,, just push a button to raise it to working height and pick the spot to work... it goes high enough to line up with my 5 x 7 roll around work table
  #127 (permalink)
Old 05-14-2008, 10:34 PM
Semper Gumby
Wiki Edits: 2
Whatdidja make?
Here's a couple of oldies but goodies
An old propane BBQ cart (with the BBQ removed) makes a handy roll-around for a MIG welder, complete with lower shelf for stuff" and a fabbed-together holder for the bottle
Another old BBQ cart will serve well as place to put your parts washer and even has selves on both sides for "dirty" and "cleaned" parts. pull the junk BBQ off and screw on a chunk of plywood (cut to fit) to hold the washer
I mounted my bench grinder onto a piece of scrap 1/8 inch steel plate. A couple of holes in the plate let me hang it on the wall out of the way when not in use, and a couple of "C" clamps hold it to the bench when I need to use it.
I welded "tongues" onto the front of my ramps - they stick out about a foot so the weight of the car is on the tongues, holding them in place as the wheels start to climb the ramps - no "skitter away" happening
  #128 (permalink)
Old 05-15-2008, 04:55 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
I made this overhead gantry crane.
  #129 (permalink)
Old 05-15-2008, 05:17 AM
schnitz's Avatar
Wiki Edits: 54
Steve, that shop of yours is too clean. I don't see an oil stain anywhere....
Really, nice job on the crane. 4 by 4's I presume?
In a while, Chet.
  #130 (permalink)
Old 05-15-2008, 07:06 AM
steve392's Avatar
just passin' thru
Wiki Edits: 2
Thanks Chet. The shop is fairly new, and the epoxy floor cleans up real easy. I haven't even had time to install the cabinets/workbenches yet...The gantry was made out of an S6x12.5 beam with 4x4x1/4" square steel "sleeves" for the 4x4 pressure treated posts.
  #131 (permalink)
Old 05-16-2008, 10:19 PM
Nothing pretty but all functional.
  #132 (permalink)
Old 05-17-2008, 07:08 AM
Rob Keller's Avatar
DETAILING GOD
Wiki Edits: 38
KEWL STUFF!
R
  #133 (permalink)
Old 05-17-2008, 03:02 PM
Rob Keller's Avatar
DETAILING GOD
Wiki Edits: 38
Updated Pixs of my home made commercial swimming pool filter housing turned into pressurized sand blaster tank.
I threw this together many years ago & now will attempt to finish it .(because I need to use it }
I will have to so a bit more fabricating.
I wonder how much these wheels will hold?
I know the drum will hold 800+lbs of sand.
I could use some imput on how to make a sand cut off valve {a plastic ball valve worked once}
R
ID:	29977   Click image for larger version
ID:	29978   Click image for larger version
ID:	29979   Click image for larger version
ID:	29980   Click image for larger version
  #134 (permalink)
Old 05-17-2008, 03:44 PM
I had never seen this thread, some great stuff! I don't have any big tools but will fashion ones all the time for the imeatiate job. They usually get tossed some where to be forgotten about so I couldn't find anymore right now. This one is one of my favorites. It is a pair of vice grips that I modified to correct the fender weld body line when I was metal finishing some Model A fenders. I made a chisel out of a 24 Buick Roadster windshield post to work in conjunction with the vice grips. It is at work, and I actually use it often.
The other one is an old favorite, jack stands made from an old V8 Ford rear end axle housing.
  #135 (permalink)
Old 05-28-2008, 07:55 PM
aminga's Avatar
A couple of years ago when I started traveling regularly I built a garbage cart for my wife to get the carts to the road and back. This week I finally got around to painting it. And since I'm playing around with learning pinstriping I went ahead and give it the old school striping treatment. The striping Looks like *** in places but it's a start. It didn't help that the dog rubbed against it while the striping was still wet.
