whats heads to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2013, 03:13 PM
whats heads to use
i got a motor in putting together, sbc 350 bored .40 over, flat top pistons, 447/454 lift cam with 256 Intake / 268 Exhaust, 212 Intake / 218 Exhaust with 110 degree seperation, (1000-5500 rpm) 650 holly double pumper, weiand street warrior aluminum intake (idle to 5500 rpm), wondering what heads to use to match my intake and cam. probably looking at cast iron GM heads for now cause im strapped for cash, looking for whats valve size would be best, thanks.
Old 08-29-2013, 10:51 PM
vinniekq2's Avatar
probably best bet would be modified vortecs
Old 08-30-2013, 08:37 AM
vinniekq2's Avatar
if your weiand is not a vortec pattern ,then maybe edelbrock e-tec/dart shp,or maybe one of the other low to medium performance heads available.If you prefer cast iron,Dart makes some nice castings.
Any of the heads mentioned can be ported
Old 08-30-2013, 12:40 PM
Which Street Warrior? These come in square bore or spread bore, polished or not, for 1955-1985 center bolt angle of 90 degrees, or 1986 to 1995 centerbolt angle of 72 degrees, or 1996 up Vortec bolt pattern. What ever the part number of this intake is will dictate head choice with in a group. Once that's know we can aim you at the best and most cost effective solution. There are some decent to excellent head choices that are new or rebuilt that are not Vortecs available from either the factory or the aftermarket. There are many factory heads to stay away from as well.
After today, I'll be out of touch till Tuesday.
Bogie
chevy, heads, intake, sbc, valves
Whats the difference in these heads??? TGCheeseman Engine 48 09-15-2010 06:07 AM
Whats what with sbc heads? bwomp969 Engine 13 06-27-2009 10:43 AM
Whats Heads for SBC? 71chevy Engine 11 03-04-2009 09:11 PM
whats the difference between these 2 heads jak327 Engine 3 02-23-2009 10:06 PM
Whats the best way to store my new Dart heads? batman09 Engine 3 02-13-2005 09:55 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
