What's proper compressed springs? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-23-2018, 08:13 AM
Irelands child's Avatar
Last wiki edit: Ford engine specifications
Originally Posted by staleg View Post
Not sure about the wire size. It's QA1.
Inner diameter is 2,5"
Wire diameter and free coils will give you an approximate capacity
Irelands child
  #17 (permalink)
Old 08-23-2018, 08:20 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Originally Posted by PHWOARchild View Post
I'd be tempted to put something sticky on top of a few coils and see if it transfers to the bottom of the coil on top of it. Maybe a little white grease that is easy to see.
Zip ties work great for this. When the coils touch the zip ties get smashed or break off. Easy to see and they stay where you put them.
  #18 (permalink)
Old 09-10-2018, 02:57 AM
staleg's Avatar
Last journal entry: Hand brake
Changed to the stiffer springs yesterday. Looks much more "correct".
Clearance between each coil before mounting was 0,6" ( 15 mm)
Mounted on car and adjusted for correct suspension geometry the clearance is 0,35" (9 mm)
Since these need much less compressing to achieve correct suspension geometry, the car has app 30% more spring length before coil bind, than earlier.
Compressed Air Question DONZIE Body - Exterior 15 10-05-2006 06:05 PM
Compressed Valve Spring Fatigue Garbonzo Bojangles Engine 8 01-25-2006 06:44 PM
Compressed gasket thickness Rhansen Engine 1 11-20-2005 01:57 PM
Bargain Time - A Compressed Breathing Air Purifier with a CO Monitor! Mike951 Garage - Tools 5 06-25-2005 07:28 PM
Alternate compressed air sources? Gearhead forever Garage - Tools 6 12-28-2004 09:31 AM
