wheel cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2018, 09:55 AM
dsr dsr is offline
wheel cylinder
hi all I've got a problem I hope someone can help me with . doing work on car drum brakes and found out that someone as fitted different drum brakes from other make of car which is unknown all I know is wheel cylinder is 13/16 bore .can I just buy a pack of seals for 13/16 wheel cylinder as its only the inner seals that have gone or will I have to replace every thing .thank you for any help
Old 08-01-2018, 11:55 AM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Dorman 13701, included boots, seals, cups. OE on mostly early Jeeps and Studebakers from the 50's and 60's.
The Following User Says Thank You to techinspector1 For This Useful Post:
Rip VW (08-01-2018)
Old 08-01-2018, 03:38 PM
dsr dsr is offline
thank you very much
Old 08-04-2018, 12:48 PM
PHWOARchild's Avatar
I worked in a place where we had kits that came with various sizes of wheel cylinders, so I had cups to fit anything for years. As long as the outer boots are ok you can change the guts after you hone them.
With my car, NEW wheel cylinders were cheaper than the kits, but if you have something hard to find new ones, just do the cup thing.
Cylinder ridge an inch down in the cylinder. What gives? DaSouthWon Engine 10 05-02-2009 05:46 AM
4 wheel disc master cylinder qckshftn56 Suspension - Brakes - Steering 2 05-23-2004 10:30 PM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 03:38 PM
Bleed Wheel Cylinder?? Dave E Shank Suspension - Brakes - Steering 6 01-03-2003 03:49 PM
front disc brake wheel cylinder??--bleeders Tom34ford Suspension - Brakes - Steering 2 06-03-2002 04:02 PM
