wheel stud replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2020, 03:39 PM
Duane lxiv's Avatar
Last journal entry: headliner bow ends
When replacing wheel studs in an aluminum hub should the knurled end be larger than the ones being replaced?
Old 07-23-2020, 07:08 PM
I don't know about larger, that doesn't sound good to me.
The Following User Says Thank You to MARTINSR For This Useful Post:
Duane lxiv (08-04-2020)
Old 07-23-2020, 08:16 PM
Big "it depends".
The knurled part can only bite into the thing so many times before you need to go larger to still have bite.
The Following User Says Thank You to cerial For This Useful Post:
Old 07-24-2020, 06:40 AM
Cridder's Avatar
Vd=0.7854B2S, CR=Vd+Vc/Vc
Last journal entry: 310 Small Block Chevy
No assuming the ones that came out were tight and there wasn't any corrosion taking place. if its a concern you could use locktight.
The Following User Says Thank You to Cridder For This Useful Post:
