where to buy SL oil - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-25-2008, 12:57 PM
Don Meyer's Avatar
Thanks Matt....I bought 3 cases of the red STP before it was pulled from the market.
I also found a 15w40 oil at a autozone store today that is SL rated. It's made by Coastal.
Don
  #17 (permalink)
Old 09-25-2008, 02:19 PM
Wiki Edits: 31
also, the AMC oil I put a link to is loaded with zinc special. and is 15w40. it's not rated but the MSDS is available
  #18 (permalink)
Old 09-27-2008, 12:16 PM
More then you probably ever wanted to know about the subject....http://www.lnengineering.com/oil.html#Z24 from the quick read looks like 1/3 to 1/2 can of EOS is about perfect however this depends on your starting level of ZDDP
Jordon
  #19 (permalink)
Old 09-27-2008, 12:47 PM
Don Meyer's Avatar
Thanks for the LN link. I had read it a while back. They are running 20w50 oil in a 911 & when I called them that is what they recommended for the Corvair.
I think that is too high a viscosity for a newly overhauled Corvair.
For the first 5,000 miles I want to use a 10w40/15w40. I'll then use a centhetic.
For break-in I want to use a 10w30 for the first 200 miles. There just is no 10w30 oil that is rated SL so I'll use a supplement w/a SM rated oil.
Don
  #20 (permalink)
Old 09-27-2008, 01:42 PM
Please keep us all informed of how your break-in goes. And ENJOY the ride. -Jim
  #21 (permalink)
Old 09-28-2008, 02:54 AM
If you have a Fred's Store in your area, their house brand oil, made by Warren Oil Co., has 10w40 and 30HD oil that are both rated SL. The guy at Warren I talked to last year said their SL oils have ~1000ppm of ZDDP in them. Warren also makes Coastal Oil products, so watch for that brand, too.
Try the store locator at www.fredsinc.com
  #22 (permalink)
Old 09-28-2008, 09:39 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
http://www.bradpennracing.com/Zinc.html
  #23 (permalink)
Old 09-28-2008, 10:22 AM
While it's not SL rating, instead it's earlier SE/SF rating- this inexpensive oil is the one I used (along with 2 small bottles STP) to break-in the cam on my 406 and it worked fine. I've found an inexpensive oil at WalMart that is still formulated to SE/SF ASI ratings and contains between 1-5% ZDDP. It's called ACCEL brand and is made by Warren Petroleum Products of Omaha,Ne .
Sounds familiar, eh?...
While I'm sure Joe Gibbs brand, Brad Penn, and all these other High-Line oils are all very good products. For those of us "on a beer as opposed to champagne budget", I don't see any problem in running oils from Warren Petroleum Products. After all, we are hopefully changing oil and filter on a very regular basis, aren't we? So long as proper additives are present in proper levels, and we are keeping it clean, isn't that the most important aspect? All oils breakdown and get dirty. Perhaps some a bit faster or slower than others, but they all do.
  #24 (permalink)
Old 09-28-2008, 10:36 AM
Don Meyer's Avatar
I found Coastal oil in a place I never thought to look.....Tractor Supply.
It is a 30 wt oil, but has the old SE/SF rating. It should be good for break-in.
Don
  #25 (permalink)
Old 09-28-2008, 10:43 AM
Should be no reason it couldn't be continued as regular/ongoing usage. Especially in your situation where engine is of older (1960's) design and you live in a pretty warm climate. Far superior to what it ran for many years, right? -Jim
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 09:51 PM
oil psi problem w/350 A355CAMARO Engine 1 04-19-2007 08:25 AM
Life time oil Filters are they a good buy? fat40 Engine 6 12-23-2006 03:50 PM
Oil Filter relocation kit... jmbjs Engine 4 04-11-2006 09:15 AM
