Where can I find Thick aluminum plate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2015, 12:54 PM
Looking for a thick 1/2"+ thick 9x11" aluminum plate to surface heads. Needs to have a perfectly flat machined surface. Anyone know where I could find this? SS would work as well I suppose.
Thanks
Old 01-14-2015, 01:09 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Metal supermarkets is my go to for small metal..And tha tis small metal..not a full sheet..
Sam
Old 01-14-2015, 01:13 PM
Sam
Thanks I'll give them a call.
Old 01-14-2015, 01:59 PM
Irelands child's Avatar
Last wiki edit: Ford engine specifications
I also use Metal Supermarket. You do pay a premium for them to cut you a small piece but it usually is well worth those few extra pennies (or bucks)
Old 01-14-2015, 02:38 PM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
Online Metals is good also. 6061-T6, 1/2" x 12" x 12" is 66 bucks n change PLUS shipping...
https://www.onlinemetals.com/merchan...=76&top_cat=60
Old 01-14-2015, 04:07 PM
Trophyman's Avatar
Last journal entry: 1939 Chevy Master Deluxe New Project(3)
Not saying this one is any batter, but I used them a lot with zero problems. Fast order processing and ship as well.
https://www.metalsdepot.com/
Old 01-14-2015, 04:26 PM
ericnova72's Avatar
More for Less Racer
If you want it guaranteed to be flat, you'll have to get Aluminum Tooling Plate....regular extruded bar or plate may not be flat enough for your intended use. Best to ask the folks you buy from about flatness.
Old 01-14-2015, 04:49 PM
thick aluminum plate
years ago I bought a surface plate.im not sure if its granet but is of that type of material. its 18"x 20" and about 4" thick. I don't know what the cost is now but I don't think it was to bad then.
Old 01-15-2015, 08:47 AM
Last journal entry: Machining Fuel Rail Stock/Fit Up
McMaster has precision ground aluminum "jig" plate as well. They have specs and everyting you are looking for.
The Following User Says Thank You to TJSBBC For This Useful Post:
techinspector1 (01-15-2015)
Old 01-15-2015, 07:00 PM
Cape Cod Bob's Avatar
Last wiki edit: How to title a hot rod
Why not try a metal fabber to make what you need like these guys near u.
Specialty Fabrication Inc | Wichita, Kansas
Old 01-15-2015, 07:53 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
You might also try a metal salvage yard. We had a place in Phoenix called Davis Salvage where I got all the metal I needed for projects. Once you have the piece in your hand, take it to a machine shop and have it flycut to flat.
Old 01-18-2015, 03:49 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
A surface place (granite) would insure that things are very flat, but to use it to get the head flat is a different story. You would need some double sided tape. then carefully tape some sand paper down beside one another with no wrinkles in it
hat is the best thing to do, is just take it to a machine shop and have it flycut flat. Or do search on CL for a lapping plate. It is a perfectly flat plate with slots in it and you use clover compound on it and rub the item back and forth ntil it is flat. You will need some Prussian Bluing to put a very thin coat on the plate, rub it around, then pull the head up and check it. You will have bare spots where the bluing does not show up on the head.
Old 01-18-2015, 04:26 PM
I know some guys do motorcycle heads with a thick pc of glass and sand paper. Never tried it . I leave machine work to machine shops.
Flex plate scraping against BOP plate? ggevaert Engine 3 05-28-2012 08:18 PM
Aluminum diamond plate 57halfton Hotrodding Basics 2 11-18-2011 03:23 PM
Few questions on cam bolt locking plate plus retainer plate. eric32 Engine 1 05-04-2009 04:19 PM
aluminum diamond plate stain johnnyford Body - Exterior 2 11-01-2007 10:42 AM
help on back-half project. can't find aluminum wheel tub liner remote Hotrodding Basics 2 08-18-2006 12:45 PM
