Where do I start on on this 48 Ford?????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2008, 05:04 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Two weeks ago I bought a 48 Ford Deluxe on Ebay that has rusted up brakes, a locked up transmission and a locked up Flat head V8. I want to sell the flat head, have already listed it in the local paper, and people have called on it. There is a guy who will buy the engine only if I can get it unstuck. I also need to get the brakes unfrozen, they are rusted solid and made it almost impossible to get it on my dads flatbed. My dad wants me to get it off the flatbed as soon as possible because he needs it in a week. The only way I can get it off right now is to hook it up to my dads 720 JD tractor and pull it off. The people who owned it before me pulled this thing out of a tree grove and busted up the front and rear suspension, I really don't want to do anymore damage right now. So where do I start, should I pull the heads off the flat head and fill them up with penetrating oil, or just pull the plugs and fill it up? Will squirting penetrating oil into the brake drums and tapping around the drums with a soft hammer free them up, or do I need to go another route? I just need to get it unloaded, parked, tarped and the engine freed up so I can sell it. I have to finish my 73 Mustang and sell it before I start this, so it is going to be my future hotrod in a year or two.
Old 09-26-2008, 05:58 PM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
Oil the crap out of the brakes....they should break loose with a bit of effort. Removing the wheels and hammering on the drums will help too.
Old 09-26-2008, 06:01 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I hauled many out of the woods
Beat those drums good ... I use a copper mallet as a lug stud protector, and belt that with a hand sledge. I do all the lugs and don't be afraid to smack it good.
Can't hurt to try the diesel in the plug holes. The last stuck flathead I had was rusted so bad, and water froze in the bores and blew out one or more cylinders. No freeing up mine...it's in China
Old 09-26-2008, 06:13 PM
onebadmerc's Avatar
It was a real bear to get up on my dads flatbed. I started out by trying to wench it up with a 3 ton come along. The only thing it did was pull the truck, the flatbed back wards and pop the ramps off. We had to jack the car up, put pieces of wood under the tires, like skids and pull it up onto the flatbed with a 1 ton diesel truck. Even then it took three hours to get it loaded up and boomed down. Those brakes are frozen solid, but it hope with a lot of penetrating oil they will free up. I hate to tear up the undercarriage anymore by pulling it off with a tractor. One other thing, how do you get those rear drums off?????
Old 09-30-2008, 02:54 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Pull the wheels off and break the cast drums with a big ball peen hammer, you don't need them anyways.
Buy 5 gals of diesel and spray everything down, including the frame. Dump all the diesel you can down the intake and pull out the plugs and fill them up to. Well that's sitting go to the crankshaft Coalition Wiki attached to this Board and read an article there called, How to Free a Stuck Engine.
Old 09-30-2008, 05:09 PM
onebadmerc's Avatar
I have most of the flat head dissembled, five of the eight bores look good, three have some rust though it is minor and one chamber would either need bored .125 guesstimate or sleeved. I broke the front drum already trying to get it freed up. The funny thing is I just whacked it twice pretty lightly with a hammer and the bottom part crumbled away. It is still frozen up as are the other three wheels. The car must have been sitting in water as the bottom of the oil pan is rusted through from outside in. This would explain why the front suspension is so rusty. I don't know what I am going to do with this 48 Ford. I might just hack it apart and sell it piece by piece and crush the rest. I am pretty disgusted with everything right now, plus it doesn't help that I am broke.
replaced head gaskets ford 3.8 & won't start Jack1991 Engine 8 12-06-2007 07:21 PM
48 ford rat rod truck tripp68 Introduce Yourself 2 09-25-2007 06:51 AM
remove center post on 48 ford coupe boatbob2 Body - Exterior 7 12-28-2006 09:51 PM
VOLARE in 48 Ford p/u BLUE BLOOD General Rodding Tech 8 02-11-2006 11:29 PM
48 Ford F5 front end Phyrkrakr Suspension - Brakes - Steering 1 07-02-2003 04:17 PM
