will 4.00 350 pistons work in my 4.00 327 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2006, 05:49 PM
To start with i might have cracked a skirt on a piston in my 327 [felt good at 5000 so 6000 must be better] motor had a rattle like a wrist pin under a load about 3000, adjusted timing back to 12 initial, was at 14, 480 480 engle e-p22 cam, dont hear rattle anymore but have not turned it too much since, i wanted to know if the wrist pin height is the same on 350 pistons or is there some other problem, since 327 pistons are way higher priced for any good piston.
Old 11-20-2006, 06:10 PM
The 350 pistons have a different compression height than the ones from a 327. If you want to use 350 pistons get the ones for a 6" rod then use a 6-1/8" rod in your 327.
Old 11-20-2006, 06:20 PM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
Sounds to me like you were getting detonation.........backing off the timing would nelp that. If the piston was broken, you would still be hearing it.
327 pistons cost more, because the 350 ones are so common.
Old 11-20-2006, 08:00 PM
i guess it could have been detination, would higher octaine gas help, im running 305 58cc heads, not for compression, just broke my good ones, with my flat top 2 valve notch pistons, what would my compression be 9 to 1 or so, Ill give her a good run this week. if no noise i want worry, new rebuild less than 1500 miles this little 327 has made a beliver out off me. Wormy. P.S. Thanks for the help everyone.
Port or Full time vacuum cool rockin daddy Engine 126 10-05-2010 03:00 PM
327 or 350? vladz Engine 13 09-05-2006 05:33 PM
302, 327 or 350? 53_belair Engine 10 07-14-2006 08:57 AM
327 block with a 350 crank hollywood2k Engine 4 07-04-2006 10:06 PM
350 and 383 piston's 70 nova Engine 5 09-30-2003 07:51 PM
