will a 6 ton press, press wheel bearings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2016, 02:54 PM
Wiki Edits: 31
Need to do a couple bearings on my Subaru. Rather than have a shop do it or take knuckles to Napa, I want to buy a press. Will a 6 ton a frame bench press do the trick?
Old 02-08-2016, 03:26 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would look for the heavy duty press at least a 12 ton or more likely a 20 ton. Once you have one there will be other tasks you will want to do.. they are not all that difficult to build if you have access to a pile of steel locally. My steel supplier has a pile of drops or cutoffs from various orders he has filled and those are available for reasonable..
Sam
Old 02-09-2016, 01:18 PM
T-bucket23's Avatar
Last wiki edit: Engine basic condition - how to check
Wiki Edits: 26
I have seen them push right out and I have seen others that a 30 ton had issues getting moving. I would get the biggest you can afford or have room for.
One work of caution on Subaru bearings.
Some Subaru's have a magnetic ring in the bearing on only one end of the bearing. The new one only goes one way but it can be put in backwards.
I had a guy bring his spindles to the garage and asked me to change the bearings. he had the wrong ones. The Napa, Autozone and Advance Auto bearings were all wrong, non magnetic. he thought I just didn't want to do it. I sent him to Subaru and he got the right ones. Unfortunately a lot of people learn this the hard way with an ABS light on after bearing replacement.
There are other cars that use the magnetic bearings as well.
Chet
Old 02-09-2016, 03:00 PM
BOBCRMAN@aol.com's Avatar
I do these, or similar, every week. A 6 ton press is marginal at best. Rusted, nasty ones, will need over 8-12 tons. If over 5 ton is required. I throw an explosion blanket over the unit and stand back.. When they "pop" STUFF goes flying...
Old 02-09-2016, 06:41 PM
Wiki Edits: 31
Guess ill buy a 12 or 20 ton.. I knew about some subarus having magnetic bearings. I think my 01 forester has a regular tone ring, but ill reference the service manual to check.
Old 02-09-2016, 06:50 PM
Wiki Edits: 3
20 ton H-Frame Industrial Heavy Duty Floor Shop Press
I will have one of these here someday.. Actually could have used it several times in the past..
sam
Old 02-11-2016, 11:49 AM
ogre's Avatar
the 'Duracell Project'
explosion blanket???
is that something i buy off the tool truck or at the local army surplus center
we had a 30 ton dake hydraulic press in the dana maintenance shop
many times we'd clear the shop and stand to the side, behind the press structure for the ''pop''
Old 02-11-2016, 04:31 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Place I know had a 50 ton that was run by an electric over hydraulic pump
That made for some scary action.It was for pressing forklift tires on and off from wheels
It was a Dake.
The owner finally got rid of it and got a 12 ton job that was a bit more space friendly as the Dake was mammoth in size for what he needed.
He challenged it with some pretty big stuff a time or two. Things did go flying once.It bent a few pieces also.
I joked with him and told him to sell it to an amish guy for cracking walnuts. I bet it would crack a Bushell at a time LOL
Fact is stranger than Fiction
Old 02-12-2016, 09:34 AM
S10xGN's Avatar
Gotta love a turbo!
I've got a 20T press and it failed separate the tapered splined axles from their hubs on my old Rambler rear axle. Would have thought that would have been plenty...
Russ
Old 02-12-2016, 10:09 AM
Guest
Location: in the land of Trolls at least till the san andreas releases the big one
buy one of these..
FWD Front Wheel Bearing Adapters
you may need one of these also to pull the inner race off the hub ... or cut it off..
Bearing Separator and Puller Set
please verify that the wheel bearing seals fit properly on the inner CV joint shoulder and on the shoulder of the hub.
EDIT..
this is probably the best video i have seen on replacing front wheel bearings that are pressed into the knuckle.. and the hub pressed into that..
https://youtu.be/xyMUtEWrHSE
notice the benz in the video does not use any seals like the toyota versions i linked images to below.. splash from the other side of the car goes right into the bearings and wipes them out..
ID:	276466   Click image for larger version
Old 02-13-2016, 05:20 AM
Wiki Edits: 31
That's a neat tool, but not something I'll ever own. The bearings I get come with a new hub. I'm hoping that I can just use a big socket the right diamater to press it. If not, I'll have to get the adapters. Subaru uses 3 seals
Improving my 12 ton press Rip VW Garage - Tools 3 12-06-2015 08:57 PM
6 ton bench press fun tech69 Garage - Tools 2 10-14-2013 10:45 AM
HF 20 ton shop press CrashFarmer2 Garage - Tools 2 08-01-2011 08:31 AM
Anyone here press off and on 9" axel bearings? MM in NM Transmission - Rearend 3 02-03-2006 07:52 AM
Removing bearings without a press.. zipfactor Suspension - Brakes - Steering 3 08-13-2005 01:12 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
