Windshield wipers 37 Pontiac - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-06-2020, 04:04 AM
Bob37pont's Avatar
Curmudgeon at Large
Originally Posted by 38 old coupe View Post
I used the same spw setup and last summer went to a car show and got stuck in a downpour on the way home.
They started squeaking and with a metal to metal sound and when I got home I took the motor cover off all the hd wheal bearing grease I used was gone and the wheel was rubbing on the outside cover.
Iíve only had them going for a year and thatís the only problem that Iíve had I baught the ones with intermittent delay
Thanks 38, my cover is readily accessable, I'll keep an eye on that.
  #17 (permalink)
Old 02-16-2020, 07:29 AM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I did a little video. Just want to add it here. A lot of good info on this thread.
The Following 4 Users Say Thank You to 123pugsy For This Useful Post:
Bob37pont (02-16-2020), Gearhead Poppa (02-16-2020), idrivejunk (02-16-2020), Rip VW (02-16-2020)
  #18 (permalink)
Old 02-16-2020, 09:12 AM
Bob37pont's Avatar
Curmudgeon at Large
I just did a brake service and lubed the slder pins with Permatex synthetic brake lube. It seems a lot stickier than the wheel bearing grease, I will try the Permatex stuff when & if the grease goes away.
For those following that watched 123Pugsy's video, the surface of the drive wheel, the connecting rod and the push assembly (as well as the cable itself) are what gets greased as the cover is what holds the assembly in place.
The Following User Says Thank You to Bob37pont For This Useful Post:
123pugsy (02-16-2020)
  #19 (permalink)
Old 02-16-2020, 06:51 PM
38 old coupe's Avatar
Last journal entry: Electric windows
I will have to try that also when the lube dries up again.
Keep us informed how it works thanks kelly
