Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiring led pilot lights? there 22mm panel lights
Old 07-29-2015, 08:12 AM
matt167 matt167 is offline
Wiki Edits: 31
the original dash lights are 194 bulbs. are these going to work, or should I put a mini voltage regulator on each? the kind that Radio-shack sells.. The Kawasaki engine has a full DC rectified charging system that runs 13.5-14.4V pretty much like any automotive system
