Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiring led pilot lights? there 22mm panel lights
Old 07-29-2015, 10:44 AM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
mini-wedge
X1,X2 usually indicates a line voltage AC source but they should work on DC assuming the voltage is correct.
The 194 bulbs should work fine and are designed for the purpose. (mini-wedge, 14 volt indicator bulb).
vicrod
