Wiring in my new welder ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2015, 09:56 PM
Hey gang I got a quick question. I have a new Lincoln 210 MP welder and it can use either 110/240v. But here's the kicker. The only receptacle the adapter fits into, is a 50amp. Now supposedly the machine only goes up to 27amps. Now does that mean I can use a 30amp breaker for it, or do i need to use a 50amp? Any help would be greatly appreciated!
Old 12-09-2015, 10:46 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
30 amp double pole breaker..#10/3 w/grd wire and yes the receptacle that you have.. Run on 220 if you can..
Sam
Old 12-09-2015, 11:22 PM
Sweet! Thanks Sam
Old 12-10-2015, 08:46 PM
Ok. Now I just got a reply from Lincoln Electric, and this is what they sent me. Hopefully you can see the attachment.
Old 12-10-2015, 09:20 PM
johnsongrass1's Avatar
Race it, Don't rice it!
On my Lincoln SP175 I use a 30amp breaker and a 50amp plug without problems at all. Even with 20 feet of extension cord I don't have issues.
Old 12-10-2015, 10:50 PM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
elect code ?
The Lincoln chart lists a 40 amp breaker for # 12 wire, The last time I looked at a code book 20 amp breaker for # 12 wire... # 10 wire for 30 amps and # 8 for a 50 amp. Long runs require larger wire sizes.
Old 12-10-2015, 11:00 PM
I know, right Tim! So since my run is a little over 100' but less than 125' I'm going to use the 40a breaker with a 8ga wire. Plus I'm wiring in my new compressor as well, and its a 24 amp motor, so that one I'll use a 30a breaker with 10ga wire. Sound about right?
Old 12-11-2015, 10:43 PM
Wiki Edits: 27
wire sizes
The shop I built in California was about 140 ft from the house main panel . I checked the code, did the calculations and ran the minimum wire size allowed. If I would have been 5 ft farther away would have had to upsize the wire. If someone was welding and the air compressor kicked on the lights would dim. don't scrimp on wire size for a long distance. And I usually go up one size for the conduit. vs conduit wire fill calculations. Our power company requires a larger size for the conduit from the transformer to the new meter than what the code book says is allowed.
Old 12-12-2015, 02:20 AM
Well I've bumped up the conduit to a 1". The air compressor is going to run a 30a breaker, and I'll be running #8ga wire for that one, and for the welder, I'll be using the 40a breaker with #6ga wire. The runs are hopefully going to be less that 100, but in case I bought about 120' of each strand. How's that sound?
Old 12-12-2015, 07:07 AM
Wiki Edits: 27
sounds good.
wire lube helps in pulling wire when you have multiple strands. and I like to leave a pull cord in with the wire in case you ever want to add something else. The main feed from the transformer to a new meter, my power company requires the larger radius elbows than an electrician normally uses.
When I built the 40 X 120 ft shop where my son now lives I wanted 3 phase power, but was quoted $ 10 K, The property was rezoned from agriculture to light industrial , annexed into the city, and now the neighbor is having 3 phase installed by the city, I ran the milling machine with a converter but only had 2/3 of the rated motor power, couldn't cut at full speed. When we put in a 3 phase farm agriculture irrigation system they had a cost sharing if multiple users would hook up to the 3 new transformers
Old 12-25-2015, 03:21 AM
Well it's all done! Did'nt have to use any lube, just a lot of choice words But the 1" conduit helped out alot. The 3 6 and 8ga wire went decently smooth inside, but when they kink, holy ****balls it sucks!!!
Welder Wiring daveh Garage - Tools 17 12-08-2011 06:58 PM
Wiring 220 for a Welder and Compressor ToddMcF2002 Garage - Tools 23 05-09-2011 08:12 PM
Welder wiring questions zimaad Garage - Tools 1 01-08-2007 11:22 PM
220 wiring for welder cboy Garage - Tools 25 02-22-2005 03:07 PM
Arc welder ~VS~ Mig Welder ChrisMiddleron Electrical 15 07-08-2003 08:31 AM
