Won't rev past 3000 rpm . - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2019, 10:53 AM
boneste624's Avatar
Vortec 350 avs2 650 carb and HeI unit off amazon..
At idle I can rev it up past 3000 just fine . But in gear if I mash the pedal the secondaries open up and it's like it hits a brick wall and wont rev past 3000. Just goes whooooooooooooooo. What could be the issue.?
Old 08-23-2019, 11:02 AM
dwighty390's Avatar
What's the timing doing?
Old 08-23-2019, 11:04 AM
vinniekq2's Avatar
whats your whoo timing at when you rev 3000 rpm? When you look down the carb throat does everything seem to be flowing? What is your fuel pressure at when revving 3,000 rpm? At 3,000 rpm does the rpm change at 1/2 throttle? Does the Whoo change in sound level or intesity,,,?
Old 08-23-2019, 11:53 AM
You need to adjust the air valve secondary (AVS2) opening rate. It is flopping wide open before the engine RPM is high enough to handle the high air flow. That is known as “bogging down” . The. Air valve secondary is one way to control the flow through the carburator. Also known as “progression”. Most carbs and multi carb set up have some form of progression.
I had two Holley 4224 Center squirt carbs on my 1962 Chevy and all eight barrels would open when I mashed the loud pedal. No progression at all. You don need progression with a drag race only car. My 55 Chevrolet had a 455 Pontiac engine.
If you want to get rid of the sudden wide open Air Valve Secondary feature, get 4.56:1 rear gears, a 454 Chevrolet engine or adjust the opening rate of the air valve secondary.
Old 08-23-2019, 12:12 PM
Is there enough air filter area, and is it unrestricted to the carb entrance, and/or
Is the fuel pump putting out enough volume/pressure at the carb to keep up with demand?
You can try running it with no air cleaner assembly to see if it is a restriction issue.
The Following User Says Thank You to toddalin For This Useful Post:
MouseFink (08-27-2019)
Old 08-23-2019, 12:39 PM
The fuel pump and air cleaner has nothing to do with the AVS2 carburetor air flow rate.
The AVS opening is controlled by adjusting the linkage on the carburetor.
I had a Rochester Q-jet on my 1969 Firebird 400 and it had a secondary opening limiter tab on the linkage. I cut off the secondary adjustment tab with wire cutters so the air valve secondary would fully open after I installed 4.33:1 rear end Gears. The Edelbrock AVS2 has a more convenient linkage adjustment so you don’t have to use wire cutters.
Old 08-23-2019, 01:29 PM
The story about the Pontiac Rochester Q-jets:
In 1967, Pontiac put the same Rochester Q-jets on the Pontiac 428, 400 GTO and Firebird 400 engines. Due to the insurance rating system of power to weight ratio, the lighter weight Firebird 400 had to have less HP than the other Pontiacs or the Firebird 400 would be in the same insurance rating category as a 1967 Corvette.
The engineers at Pontiac solved that issue by putting a AVS limit tab on the secondary air valve linkage. The limit tab would only allow the air valve to open 3/4 from vertical or from being wide open. That reduced the engine Horse power rating from 360 HP / 400 CI GTO without the limit tab to 335 HP / 400 CI Firebird 400 with the limit tab. That also reduced the insurance rate by about $100 per month.
You can raise the HP on a Firebird 400 from 335 HP to 360 HP by merely cutting off the AVS limit tab on the Rochester Q-jet carburetor secondary opening linkage.
Smart fellers, those Pontiac engineers.
Old 08-23-2019, 02:38 PM
chasracer's Avatar
True Hotrodder
Do you have another carb or one that you can borrow? That would tell you a lot and I am guessing that you don't have a fuel pressure gauge to measure pressure but when did this start happening? Are these recent changes to the engine?
Old 08-23-2019, 04:21 PM
Regap the plugs to .030, replace them and gap those to .030 if the plugs are old or fouled, then test again. These E bay distributors often perfer a tight plug gap. They run nice in the lower RPM's but crap out around 3000 with a lot of throttle. I've found tightening the plug gap often helps these ignitions. This is not to say there isn't a carb issue but you have to check these things out and I like to start at simple and cheap to do then work up.
Usually if the secondary air valve comes on too early it is a transitioal thing that the engine will stagger through and eventually get going.
Bogie
Old 08-23-2019, 07:11 PM
meborder's Avatar
Is this an automatic transmission?
I had a car that would go like stink up to about 3,000 and then just nose over and accelerate slowly after about 3,000. If you held it to the wood it pull clean to the governor (in the trans) but would do it at a snails rate of acceleration. Did this in all gears. Short shift it and it would go like stink. Wouldn’t go over about 85 in third but would easily top 100+ in OD.
The final fix was to rebuild the transmission. Then it pulled hard in all gears all the way to the governor. Something in the trans was unhappy at high engine rpm.
Food for thought
Old 08-24-2019, 06:58 AM
55 Tony's Avatar
You should be able to determine if it's the carb by slowly opening the throttle, easing the secondaries open slowly. If that works then for sure your carb is opening too fast. I work on Q-jets, I've never seen the edlebrock version so can't help on adjustment.
Cheap and easy to try.
Young enough to learn ... too old to remember.
Old 08-24-2019, 09:15 AM
The Edlebrock instruction book that came with the carb gives explicit instructions as to how to adjust the secondary air valve, experience at this has taught me to follow their instructions. These instructions are also on line if you can't find the booklet.
Not that I think this is the total problem, but proper adjustment is necessary especially if you tried going off on your own, like I never did that.
But reread my earlier post, it too is bore of unpleasent experience and subsequent discovery. Always remember the old rule of carburetors; "most carburetor problems are electrical".
Bogie
Old 08-24-2019, 11:55 AM
The so-called “anti pump up” hydraulic lifters will pump up and float the valves about 3000 RPM and the car will nose over and stop pulling. They act as a rev limiter. My associate had a 1967 GTO that would nose over at 3,000 RPM and it felt like he turned off the ignition key.
I used solid lifter camshafts in my two Pontiac motors in 1969-1970. I risked spinning rod bearings over 6,000 RPM until I rebuilt the rods using ARP bolts. I used Pontiac Ram Air IV limited travel hydraulic lifters in the three Pontiac motors I built in 1971-1980. I could spin those motors up to 7,000 RPM with a 4.33:1 rear gear ratio in my 1969 Pontiac Firebird 400.
The Pontiac limited travel lifters were discontinued in 1990. Comp Cams and other cam grinders started offering limited travel lifters in 1994 for GM engines. Those lifters set at .002” preload and have only .050” total plunger travel. You must use 7/16 rocker studs and poly locks to set the preload. Those are often called “cheater” hydraulic lifters in stock class racing that requires hydraulic lifters.
Old 08-25-2019, 10:04 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
When you hear that "whaaaa," it is almost always a lean condition. Fatten up the secondaries.
Old 08-25-2019, 02:56 PM
That’s right. When you hear “woooo” means the secondaries are right.
