Your choice for chassis / underbody coating - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2017, 08:56 AM
Wondering what you all would choose to put on the bottom of a sand blasted and epoxy primed unibody car.
My thought was either chip guard or matte black single stage urethane.
Are there better options? If I go with chip guard, can anyone advise on the best product to chose? SEM 1k, 2k? I see they have both.
Old 09-12-2017, 09:28 AM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
I would go with the single stage urethane. It is a lot more forgiving if you ever need to do work under there and it is easily touched up. The paint will also let the underbody breath and it will not lock water into the seams like chipgard or undercoating tends to do.
Mark
Old 09-12-2017, 03:20 PM
Mark
thanks. good input!
Old 09-12-2017, 05:23 PM
idrivejunk's Avatar
Grand Prix user
Last journal entry: Last look
It doesn't have to be an either / or situation, a currently popular choice in my area is applying a textured chip resistant rocker guard coating then paint.
The Following User Says Thank You to idrivejunk For This Useful Post:
mitmaks (10-16-2017)
Old 09-12-2017, 05:56 PM
Any recommendations on chip guard? I see 2K SEM, 1K SEM, 2K Dominion. 1K SEM with the option of touching up with rattle cans some day sounds appealing, but only if it works well.
Old 09-12-2017, 06:17 PM
idrivejunk's Avatar
Grand Prix user
I only see it done using 3M rocker guard, either from a quart through a shutz gun or the "no cleanup" setup they offer. Body color is usually chosen for underneath and flat clear is used over it but that could just as well be single stage black urethane. If I had to have just one thing sprayed underneath though, I pick the SS black paint. What you are talking about sounds like catalyzed or uncatalyzed undercoating and I have no experience with that. SEM makes quality products, I'll say that.
Old 09-24-2017, 06:57 PM
carolinacustoms's Avatar
Automotive Extraordinaire
We have left them in SPI Epoxy primer (red oxide or black depending on owner preference), painted over the epoxy, and used raptor liner on the bottoms of them as well. If it is a rarely driven show vehicle or an auction ride, I'd suggest epoxy or paint. If it will see the highway pretty regularly, I recommend raptor liner or a similar air cured spray on bedliner. I don't usually suggest rhino or linex type products, due to their thickness. Just what we do here.
Kelly
The Following User Says Thank You to carolinacustoms For This Useful Post:
22george (09-25-2017)
Old 10-16-2017, 08:33 AM
mitmaks's Avatar
Last journal entry: Grille
One of my customers had local shop do a Rhinoliner? on inside of his pickup bed. Unlike regular bedliner its flexible, you can press fingernail into it and it will flex. I think it would be great undercoating material that would resist any rocks as they would just bounce off of it.
Old 12-07-2017, 09:00 PM
I always uses a Rust -oleum red oxide primer--oil base on rusty metal first--and mixed 1 gallom gloss black and 1 gallon flat together---that gives you a seim-gloss look.I used it on the chassic and under hood.
'77 Camaro Underbody Stabilization Livgardet Body - Exterior 0 07-07-2015 08:55 AM
Underbody rust prep Hwyhogg Body - Exterior 3 03-20-2014 08:24 AM
Best Chassis coating? lamothe1 Body - Exterior 10 10-07-2011 07:08 PM
underbody..rust convertor help please... Rubberman2003 Body - Exterior 1 06-26-2003 02:08 PM
37 Plymouth on S-10 chassis - Good choice? Too-tall General Rodding Tech 2 04-11-2003 09:39 AM
