I'm getting ready for final assembly on a very basic budget rebuild of a 350.
specs
350 with 0.020" oversized pistons/bore
flat tops with 4 valve reliefs
~0.045 in the hole based upon what I measured at teardown. I believe this may be due to something like 0.025 deck height and 0.020 jobber rebuilder pistons with the reduced compression height. But just a guess based on some reading.
Vortec heads
fairly basic 0.462/0.470 lift COMP CAM
Likely Felpro 7733PT2 PermaTorque head gaskets; 0.040 compressed thickness
this is approximately static 9.3:1 assuming 6cc for valve reliefs and 64cc for vortecs (I've heard 62cc may be actual)
could be ~9.5:1 if they are 5cc and 62cc values.
As you can see, I'm using the basic and forgiving 0.040" compressed PermaTorque head gaskets so my quench is going to far from the ideal 0.040". looks to be 0.085" or so. (I need to remeasure the deck height again to get exact numbers.)
A friend gave me the short block so I honed it myself, measured it, and threw in all new bearings, rings, and cam. Reused the whole rotating assembly. The engine ran well in its previous life with early camel hump heads and a 0.440/0.460" cam. So, with the better vortec heads I don't imagine I'll have much problem running it like I have it setup. I didn't have any machine work done myself hence why the pistons are so far down.
Does any one have any reservations to what I'll be putting together? I think machine work is out of the question at this point due to budget and progress so far, as well as the previous iteration working OK. My only other option seems to be the felpro thinner 0.015 head gaskets. However, from what I can tell I do not believe these will work out since I didn't have the bock decked and the surface prep'ed for these. re: typical budget rebuild head and deck surface.
also, often you see rebuilds reusing the 12cc dished factory type pistons. The only tight quench area on these is with the thin outer radius of the pistons that isn't dished. Does this thin outer ring really affect quench more beneficially vs what I'm running with the flat tops? Seems as if the dish shape doesn't result in much quench benefit.
Thanks!
specs
Vortec heads
Thanks!
