Vortec heads can be ran with a 2.05" intake and a 1.6" exhaust valve, but the port work needs to be done to use these alves or you will have worse performance than you would with stock valves. A well ported set of Vortecs with stock size valves can put out over 500hp on pump gas though, so they can be plenty capable of supporting the power many people are after. They are not aftermarket heads though and they're are many good options for only a few dollars more.
