1 - 2 of 2 Posts
I am running a 10 bolt posi with 3.42 gears. It is an "S" spring carrier. When I turn right or left from a stop I feel a binding in the differential. I am running Castrol gear lube with the posi additive.
Is this a sympton of worn clutch plates in the posi? If so, where can I purchase replacements?
Differential/Driveline
Normally if the plates are getting worn it will not chatter because the unit looses preload. I would pull the cover and look for some bad teeth on the side's and spider's. If everything looks good refill with fresh oil and additive. I hate to admidt it,but the FORD motorsports additive works better. :D
1 - 2 of 2 Posts
