i have a 1989 chevy blazer with 7" lift on 38x15x15 wheels with 700r4 with 373 rear swap. 350 std. bore and stroke with .275 dome piston with estimated 11.88:1 compression. I am budget building and wondering what the best cam to use would be. I have stock 193 heads that i will be porting. preferably a torque engine. i was looking at comp cams xtreme 4x4 cam with, 262° Intake / 270° Exhaust, Duration @ .050'' Lift:218° Intake / 226° Exhaust, valve lift with 1.5 rockers .462'' Intake / .480'' Exhaust, and 111 lobe separation. i guess what my question is. can my heads except this amount of lift and is this a good cam for my application. i am hoping for a lope noticeable idol. Its a weekend worrier not a daily driver and only sees road between mud holes. Any and all help would be beneficial.
The 193s are intended to get good gas milage at low RPMs in a heavy truck they aren't necessiarily meant nor do they create large low end torque numbers. Most any late model double quench, centered spark-plug, fairly modest port and valve size head will do that. What these heads really do is limit the upper RPM band. They gain very nicely to about 4300 then level off to about 5 then just quit. Figure that in your gearing and tire size.
If by porting you mean getting rid of the swirl vane you're on to something, they will wake up when ported but it's a lot of work. Check out castings 14096217 and 14011083 these are sold as cast iron L98 heads which is pretty much the same thing as the 193 with no swirl port vane to cut out. They are usually pretty cheap because nobody's looking for them. Heres where it gets tricky:
Part number 10159552 is the 55-86 version with 90 degree center holes, it is made from castings 14096217 or 14011083.
Part number 10125377 is the 1987 and up version with 72 degree center holes. It is made from castings 14096217 (sound familiar?) or 14101083 (watch this it's sooo close to above but it is different) these will fit your 89 TBI intake, or what ever intake you're running against the 193 heads.
All of these are 64 cc chambers with 1.96x1.5 valves and have a 170/175cc intake port. They are found on TPI and TBI passenger and cop cars including Camaro and Firebird.
A rebuilder may take your 193s as cores and save you some money.
