Hey,
I have 2 options frame wise for my 34', since buying a new one is out of the question due to my budget.
I can either use the original 1934 Chevy Frame and use a MII front end and 8.8" rear end, or use a frame from a newer car, such as a S10, and use the MII front and 8.8" rear on that frame as well.
There are pros and cons to both I would expect.
I am not sure which to use, but this is what I have been told I would have to do with an S10 frame in order for it to fit on my car, and I was wondering if anyone could verify this for me:
"You have to narrow the width, change the front of the chassis, frame rails, front crossmember, notch the frame so the fenders will fit right. make a radiator support bracket, notch the back of the body since the s10 has more kickup."
Which would you use if you were me, and for what reasons??
Thanks!!
Thanks!!
